Old 09-29-2011, 03:49 PM   #1
blazntn
6lug to 5 lug
Ok I have 6 lug disc and drop spindles on my 69 C-10. I am thinking of converting to 5x5. Just wondering what it takes to do this?
thanks
blazntn is offline   Reply With Quote
Old 09-29-2011, 04:24 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 6lug to 5 lug
Who made the spindles? if they are GM, then your just gonna need the spindles, calipers and rotors from a 5 lug truck.
There are plenty of 6 lug wheels out there especially from the GM group, why change to 5 on 5
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-29-2011, 05:04 PM   #3
kieth
kieth's Avatar
Re: 6lug to 5 lug
thanks
If you used later model hubs to go to disc brakes, just go down to O'reileys and get new rotors and hubs (1 piece) if it was a stock conversion....only cost $32.00 plus the wheel studs. reuse the old wheel bearings if they are good. you are now converted to 5 X 5.
In the rear end I just had the axle hubs redrilled to the 5 x 5.....
I actually did the conversion to 5 x 5 and found out the wheels I had purchased were 5.x 4.75 had to convert and redrill but it did turn out worthwhile. Kieth
kieth is offline   Reply With Quote
Old 09-30-2011, 03:22 PM   #4
blazntn
Re: 6lug to 5 lug
I am not sure about what brand they are. PO put them on and I dont see any markings. I was hoping to go to the local parts store and pick up what I need.
thanks
Brad
