Old 04-13-2003, 08:57 PM   #1
gmc67swb
gmc67swb's Avatar
Up And Running With Efi
GOT MY PROJECTION INSTALLED AND WORKING TODAY! THROTTLE RESPONSE IS GREAT AND THE START UP IS SWEEEET! JUST HIT THE IGNITION SWITCH AND THAT'S IT. NOW MAYBE I CAN GET THAT MAGIC 20 MPG.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 04-14-2003, 11:37 AM   #2
lpaine
lpaine's Avatar
Sounds cool, what kind of efi are you running? If you can get 20 mpg that would be awesome- I guess your wife will be happy to get the kitchen table back!
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 04-14-2003, 11:23 PM   #3
DANL
Hey, can you post any photos?
...Dan
DANL is offline   Reply With Quote
Old 04-15-2003, 04:47 PM   #4
nate68
what efi setup are you running? mpfi, tbi, tpi?
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 04-15-2003, 04:55 PM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
Definitely get us some pics - sounds great!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-15-2003, 05:00 PM   #6
bpmcgee
bpmcgee's Avatar
He said "Projection." I think this means the Holley Pro-Jection TBI system.
Please definitely give us some more information and pictures! I just bought this and I'm a little daunted by the prospect of adding this to my 71 blazer!
Thanks,
Brian
bpmcgee is offline   Reply With Quote
Old 04-17-2003, 01:36 AM   #7
nate68
they still make the "pro jection" systems? i heard they were crap but the new C950 systems are supposed to be pretty rad
Old 04-17-2003, 09:50 AM   #8
bpmcgee
bpmcgee's Avatar
Yeah, the Pro-jection system is the only system they have on their website for tbi injection.
I've actually read good things about this system -- that's why I decided to take the plunge.
I suppose we'll have to wait for gmc67swb to break our suspense.
Brian
Old 04-17-2003, 03:43 PM   #9
Chevyguy111786
I'm considering goin with an EFI system for my 70 chevy LWB 350. But was wondering what kinda horsepower increase, gas milage increase and what kinda dent it will leave in my wallet. Any idears?
Cory
Chevyguy111786 is offline   Reply With Quote
Old 04-17-2003, 03:45 PM   #10
nate68
they make a tbi with the C950 now. about 1400 i think.
Old 04-17-2003, 09:08 PM   #11
Project1970
14.1 @ 96MPH
Project1970's Avatar
How much did it cost you and how hard was it?
I'm thinking I'll go TBI one of these days (any other solution on Vortecs gets pricey!!!) and I'll probably go the homebrew route...use a big-block TB with 2" bores, and the Megasquirt kit ECU.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-17-2003, 11:01 PM   #12
gmc67swb
gmc67swb's Avatar
THE SYSTEM IS THE 2-D PROJECTION(DIGITAL COMPUTER). THE INSTALL IS STRAIGHT FORWARD. THE SYSTEM FUEL PRESSURE IS FACTORY SET AT 15PSI BUT IS ADJUSTABLE IF NECESSARY. WITH ONLY 15PSI YOU CAN RUN RUBBER HOSE INSTEAD OF HARD LINE. THE COST WAS $775.00. AS FAR AS IT BEING CRAP, I DISAGREE. OF COURSE, I'M PARTIAL BECAUSE I OWN ONE. I CAN SAY ONE THING, WITH A WEEKS WORTH OF DRIVING, IT'S BEEN NICE JUST G0ING OUT AND TURNING THE IGNITION KEY. AND HAVING THE TRUCK START RIGHT UP. ONE DOWN SIDE MAYBE THAT THIS PARTICULAR UNIT IS DESIGNED TO SUPPORT ONLY 275HP. NO PROBLEM FOR ME BECAUSE MY TRUCK IS A TRUE COMMUTER TRUCK. I DRIVE IT DAILY. THE THROTTLE RESPONSE IS MUCH CRISPER AND IT TAKES LESS PEDAL EFFORT TO MOVE THE TRUCK.
I USED THE VENT LINE ON THE SENDER TO RUN THE RETURN LINE. THE FUEL PUMP IS MOUNTED INSIDE THE PASSENGER SIDE FRAME RAIL JUST UNDER THE DOOR. THE FUEL PUMP IS QUIET AND COMES WITH A RUBBER ISOLATOR TO CUT DOWN ON VIBRATION. THE COMPUTER HAS POTENTIOMETERS TO ADJUST IDLE, CHOKE, HIGH RPM, ACCEL AND THERE IS MAIN THAT ADJUST THE WHOLE FUEL MAP. THERE IS ALSO AN OPTION FOR AN O2 SENSOR. THIS WILL ALLOW THE COMPUTER TO ADJUST THE AIR FUEL RATIO WHILE YOU DRIVE.(FUEL ECONOMY)
Old 04-17-2003, 11:03 PM   #13
gmc67swb
gmc67swb's Avatar
THE COMPUTER
COMPUTER
