Old 09-30-2011, 08:52 AM   #1
jasons
not enough hours in the day
jasons's Avatar
Delay wipers don't work
On my 85 the delay wipers don't work. I have tried three different modules. I was told they were good, but don't have another vehicle to test them on. I tested the resistance of the delay switch and have a range of 50 to 500 K Ohms which is were it should be according to my research.
Does anyone have a wiring diagram for the wipers or any ideas where the problem may be?
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
& piles of spare parts
jasons is offline   Reply With Quote
Old 09-30-2011, 11:36 AM   #2
LONGHAIR
Re: Delay wipers don't work
The only ones I have ever seen were fixed by replacing the module. Are you sure that the motor itself is ok?
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-30-2011, 11:47 AM   #3
jasons
jasons's Avatar
It works in both low and high speeds and the mist function works, just not delay.
I believe the wipers run in low speed when on the delay, I'm wondering if the switch is not powering the low speed circuit when the delay is on. I need to search for a wiring diagram.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 10-03-2011, 05:41 PM   #4
jasons
jasons's Avatar
Anyone else run into this?
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 10-03-2011, 10:13 PM   #5
Hubscrub
Cruzin
Hubscrub's Avatar
My 85 is the same i replaced the module no difference haven't whent much futher yet. Low and High work fine so do the mist and washer.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 10-04-2011, 01:14 AM   #6
spencer_41188
spencer_41188's Avatar
mine dose the same thing its a 87 and the wiper motor was striped when i bought it so i changed it and theres no diffrence between low and high and my wipers dont even go to the botom when shut off it would be nice to fix it so i dont have to time it just right
spencer_41188 is offline   Reply With Quote
Old 10-04-2011, 09:39 AM   #7
hatzie
Moderator
hatzie's Avatar
http://coloradok5.com/forums/showthread.php?t=174785
I attached the 1989 R/V square body pulse wiper schematic. I can't guarantee the colors are the same from 1984-1991.
I don't have a schematic for the pulse module itself.
Old 10-04-2011, 10:42 AM   #8
jasons
jasons's Avatar
Hatzie,
That diagram is what I was looking for. Now I just need to find a little time to troubleshoot the system.
Jason
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
