Old 09-30-2011, 12:38 PM   #1
DeputyDan
375 Transmission
Anyone ever heard of a 375 tranny? Tailshaft seems to be the same as 350 will a 350 tourqe conv work in a 375? Any other considerations when swapping a 350 for a 375 that is the same length?
DeputyDan is offline   Reply With Quote
Old 09-30-2011, 01:09 PM   #2
RUSHNBOBO
Re: 375 Transmission
It all depends on which one you have read below:
THM375B - This trans is identical to the THM350, but is considered a heavier duty transmission.
THM375 - This transmission is a derivative of the THM400 sharing the external appearance of the 400. It'll be marked 375-THM on the bottom of the tailshaft housing. It's a light duty version of the THM400, has ABSOLUTELY NO RELATION to the THM375B, and was found in 1972 to 1976 full-size cars. The Turbo 375 was modified to accept the Turbo 350 driveshaft yoke.
The THM375 and has a long output shaft that mates to the smaller THM350 drive shaft yoke. Internally the clutch packs originally had fewer friction plates. Some "Heavy Duty" THM350s were also designated THM375-B.
RUSHNBOBO is offline   Reply With Quote
Old 09-30-2011, 01:10 PM   #3
MARKDTN
I would stay away. It is a strange combination of a TH350 and a TH400. I believe the torque converters do interchange with all 3. There is no aftermarket support. As cheap as you should be able to find TH400 nowadays, that is where I would spend my money. Better yet do a 700R4 swap.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 09-30-2011, 02:06 PM   #4
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Exclamation Re: 375 Transmission
I would have to agree with you on this point.
Stick with a TH350 or 400; or go overdrive with the 700R4.
Good luck
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 09-30-2011, 02:14 PM   #5
RUSHNBOBO
If it's a THM375B, it has no relation to THM400.....they are identical to a THM350 with a few heavier duty parts. All aftermarket parts are compatible.
Old 09-30-2011, 03:37 PM   #6
LEEVON
LEEVON's Avatar
I had one in an '87 swb silverado, factory. It started slipping and when I pulled it nobody would buy it, coudn't even use it for a core. Nothing wrong with the TH400/TH350 tailshaft version from what I understand though.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-30-2011, 03:46 PM   #7
RUSHNBOBO
That doesn't surprise me....they probably didn't know what it was
