Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-30-2011, 04:19 PM   #1
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
im having problems with the rear end
im having a hard time from keeping the rear end down on the ground ,im getting real aggrisive wheel hoping left to right ,not bounce but hard to keep control ,its 4 link system ,when i take off from dead stop it burnout nice until 2nd kicks in then wheel hops starts ,today i was rolling and jump on it ,the front end was going back and forth like crazy ,almost felt like it was going to flip on its top .
any suggestion .i did adjust the 4 link once and it hook up good .
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 09-30-2011, 04:28 PM   #2
70shortwide
Re: im having problems with the rear end
when my buddys truck was getting tire shake the shocks in the coilovers were leaking (from being old) he replaced them and fixed the problem.
70shortwide is offline   Reply With Quote
Old 09-30-2011, 05:03 PM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
beat me to it shortwide..... Shocks are not doing their job. Stiffen them in both directions and see what happens.
For the 4link,, typical race setup is lower bar parallel with the track, upper drivers side bar to set pinion angle, and add any pre-load with the passengers side upper bar.
For high HP, hard hitting cars (6-8 second stuff) they typically start with lower bar slightly pitched downward just enough that you get a IC 45-50" in front of the rear axle centerline, and 4" above the track.
I love Dave Morgans statement that "misery loves a bunch of adjustment holes in a suspension bracket". If your not willing to putz with the 4link to find exactly what your combination likes at every track you go to,,, you probably would be better off with a ladder bar setup.
(all that coming from a guy that has two 4link cars that are probably set up so WRONG it's not even funny)
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-30-2011, 05:15 PM   #4
fastwillie 696969
~Rest In Peace~
everything is brand new
Old 09-30-2011, 05:17 PM   #5
fastwillie 696969
~Rest In Peace~
i'll try that thanks
