Old 09-30-2011, 04:49 PM   #1
srich1207
Engine Ticking
OK guys just got the 72 C10 350 rebuilt and in the truck. I have an engine test stand and it ran perfect and runs perfect now that it is in the truck. Except for the fact that I have a ticking sound, its not an exhaust leak, I thought the valves needing adjusting again and that would fix it. Well I did it while running and once the slack was out I turned it another 3/4 turn. And I must say don't want to do it again while the engine is running what a freaking mess oil everywhere. Anyway I can't get the ticking out. When I first crank it up there is not ticking but after a couple of minutes it starts ticking. If I go in lets say to get something at the store for 5-10 minutes and come out crank it no ticking then after a couple of minutes it comes back. Does anyone have any ideas here is my setup.
350 bored .040 over
E-Street 2.02 Aluminum Heads
HE Comp 268 Cam
Flat Top Pistons
About 9.3 to 1 Compression
Edelbrock 600 CFM Carb
Edelbrock Aluminum Intake
1.5 Roller Rockers
Headers
Any help will be greatly appreciated.
srich1207 is offline   Reply With Quote
Old 09-30-2011, 04:57 PM   #2
cleszkie
cleszkie's Avatar
Re: Engine Ticking
Could be a bad lifter (compressed with slow rebound) or poor flow to lifter. A lifter without oil will tick until it gets it. Just a guess without actually hearing it. Good luck.
cleszkie is offline   Reply With Quote
Old 09-30-2011, 05:03 PM   #3
71 GMCDRVR
71 GMCDRVR's Avatar
Re: Engine Ticking
Sounds like a lifter, did you break the lifters and cam in properly??? I did this same thing when i dropped in my 383 and ended up roachin the cam!!!!
Blessings, Ryan G
JESUS IS LORD!!!!!!
71 GMCDRVR is offline   Reply With Quote
Old 09-30-2011, 05:06 PM   #4
royboy
Re: Engine Ticking
Is flex plate cracked?
royboy is offline   Reply With Quote
Old 09-30-2011, 05:12 PM   #5
71 GMCDRVR
71 GMCDRVR's Avatar
Re: Engine Ticking
Does it sound like its coming from the valve covers?
Blessings, Ryan G
JESUS IS LORD!!!!!!
Old 09-30-2011, 05:22 PM   #6
cdowns
cdowns's Avatar
Re: Engine Ticking
exhaust leak/flexplate hitting dustshield/ sagging motormounts causing fan to hit shroud
Old 09-30-2011, 09:55 PM   #7
Boog
laying low
Boog's Avatar
Re: Engine Ticking
I have had a fuel pump to peck and sound just like a lifter. Use a long piece of heater hose to try to locate the source of the tick.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-30-2011, 10:00 PM   #8
landsurvey1
landsurvey1's Avatar
Re: Engine Ticking
Timing advanced too much?
landsurvey1 is offline   Reply With Quote
Old 09-30-2011, 10:39 PM   #9
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Re: Engine Ticking
What type of rocker are you using? do you have a part number? Is it possible that your valvetrain may be setup incorrectly?
The E-street heads use a guide plate and hardened push rods. If you are using this setup then you need to use non-self aligning rockers or you will bind the push rod. My understanding is that the bound up push rod cannot move as fast as it should as the valve opens and closes and this can cause a tick or tapping because it is allowing too much clearance between valvetrain components.... It can also cause the push-rod to fail which causes a he77 of a mess.
If you are not using guide plates then you may need to run self aligning rockers.... You would have to contact Edelbrock on that....
screamin_c10 is offline   Reply With Quote
Old 09-30-2011, 10:48 PM   #10
screamin_c10
Re: Engine Ticking
Also, check the roller tip on those rockers, they can wear out and loosen up causing a tick or tap...
Old 10-05-2011, 04:01 PM   #11
srich1207
Re: Engine Ticking
Hey guys thanks for all of the great advice to check but just letting everyone know I have found what was causing the problem so for anyone who has this problem. I put a set of Summit Brand stamped steel roller tip rocker arms on the engine and have had a ticking noise ever since. I checked for exhaust leaks none, reset the valves atleast 4 times still ticking. So I changed the rocker arms to a set of stock stamped steel rocker arms and no more ticking. Once I tool the roller tips off I noticed the pivot ball wasn't contacting the arms correctly on all of them was wearing on about 20-30% of the surface where it should be 100% contact. But just letting everyone know what the problem was and that Summit Racing stamped roller tips suck and are noisy as hell.
Old 10-05-2011, 04:29 PM   #12
71 GMCDRVR
71 GMCDRVR's Avatar
Re: Engine Ticking
I have comp aluminum roller rocker arms, and they are noisy as well they have that sewing machine sound. just something I have learned to live with. I am glad it wasn't your cam or lifters
Blessings, Ryan G
JESUS IS LORD!!!!!!
Old 10-05-2011, 07:19 PM   #13
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: Engine Ticking
Had a similar problem with summit roller rocker arms. Roller tip came out on one side - tick, tick, tick... Found it before it did any damage.
Now, I run comp cam rollers-self aligning. No problems.
D.PASSMORE is offline   Reply With Quote
Old 10-07-2011, 02:24 PM   #14
re1
re1's Avatar
Re: Engine Ticking
My fuel pump is making a ticking sound just like a lifter,not sure why but it
seems to work fine .
1972 Chevy C10 Custom Deluxe Highlander
1972 Chevy C10 Custom Deluxe Medium Green
re1 is offline   Reply With Quote
