09-30-2011, 04:51 PM | #1 |
Big Block parts: Steal ?
Found a 70 1/2 ton that had 396 I was told. Has a 400 badge on the
fender, 396 on the inside glovebox. Has 2 altenater brackets(all there?) powersteering pump and resevore with 2 brackets i believe. (all?) Motor stands $65 for all of it. Seems pretty good to me. Is it all there, anything else i should look for a BB application?
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
09-30-2011, 04:57 PM | #2 |
VA72C10
Re: Big Block parts: Steal ?
Grab everything you can!!! STEAL of a deal!!!
If there.... The aircleaner with the spark arrestor and heat riser, the hei, the carb, the exhaust manifolds, heat shield bolted onto the lower passenger firewall, the tranny bracket on the firewall and the linkage with it, and whatever else at those kind of prices
Looking for a 67-72 swb or blazer project in or around VA. |
09-30-2011, 05:05 PM | #3 | |
brackets laying inside on the floor board.
09-30-2011, 05:22 PM | #4 |
VA72C10
Kind of like a U-shape with a point on the back side...then a slightly bent rod with a pivot is the tranny linkage.
