09-30-2011, 07:33 PM | #1 |
Active Member
01 GMC Sierra 1500 4x4 5.3 rear interchange?
My work truck, has 265K miles and runs great. Had a small diff fluid leak at left rear axle near perch, turned out to be a hairline crack on axle tube, about 3'' long. Has been like that for about a month with no problems. Last night the wheel bearing burned out? My welder guy says maybe crack could be welded, but probably cracked from torking and would probably happen again? So, I'm now looking to replace the whole rear unit. What GMC Chevy years/models will interchange? Has 373 gears. Thanks
10-01-2011, 08:11 AM | #2 |
Re: 01 GMC Sierra 1500 4x4 5.3 rear interchange?
Check out www.car-part.com will show you everything that will work and what out in the junk yards
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
10-01-2011, 11:43 AM | #3 |
Has more rust than truck...
Should be any 99-04 1500 with 3.73s. In 05 they went to drum brakes and I'm not sure if they can be easily swapped.
