Old 09-30-2011, 10:19 PM   #1
Bigwolfe87
Young Newbie!! Need Help- Does 68 cab/parts fit 71 chassis?
Hey guys I just picked up a project and I beginning to gather parts to start the build. The truck I have is a 68 chevy c10 camper special with a 327 and 3 on the tree. I just found a guy who wants to sell me a 71 chevy c10 roller. I know it has disk on the front and 5 lug wheels on the frame. Can I put the 68 cab, hood, fenders, grill on a 71 chassis to get the brakes and suspension or should I just sway the cross member?
Under Construction....but determined to finish
Bigwolfe87 is offline   Reply With Quote
Old 10-01-2011, 05:14 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Young Newbie!! Need Help- Does 68 cab/parts fit 71 chassis?
yep...they'll fit...you'll need to buy the 60-68 rad support bushings to make the front clip fit nice on that 71 frame...
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 10-02-2011, 08:33 AM   #3
Keep everything that goes with the '68 body and you're good. The e-brakes are different,so use that cable and the hole in firewall/wiring harness plug are different (at fuse block),so stay with the '68 stuff.
Just re read your post and it looks like you mainly are looking to get the 5-lugs discs. Yes,that entire assembly is interchangable and you'll want to swap everything from pedal rod to master cylinder to proportioning valve. The rears will swap directly.
Your '68 is a C/10 Custom Camper?? Got pics?
