Old 10-01-2011, 11:54 AM   #1
jdheff1982
Question TH-400 Questions
Hello,
My truck has a TH-400 tranny and I am experiencing some odd functionality of the unit.
If I am cruising and suddenly stomp on the gas, the engine gets louder, but the RPM's do not increase nor does the tranny kick-down. The engine is not suffering from lack of power or what not. Also, the tranny won't shift from 1st to 2nd until the engine hits about 2500 RPM's no matter where my foot is on the gas.
Last thing, what can I do about column shift slop? And how do I get the gear selector indicator to work? I have tried to reclip it to the plastic sleeve, but it gets pulled off easily.
Thanks.
Project and Truck Specs: http://67-72chevytrucks.com/vboard/s...d.php?t=483381
jdheff1982 is offline   Reply With Quote
Old 10-01-2011, 06:08 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: TH-400 Questions
check the fluid level and color if its low add some if its brown and burnt start saving for a new trans.. if its brown and not burnt smelling change it and the filter..
the only way youre fixint the thing with the indicator is to either tighten the clip or replace the part of the coumn it rides on
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-01-2011, 06:43 PM   #3
MikeJones16
MikeJones16's Avatar
what he said^
If the gear selector move around but kinda gets "lost" your little wire could be snapped or loose.
MikeJones16 is offline   Reply With Quote
Old 10-01-2011, 07:23 PM   #4
Dunenutt
Newbee
Dunenutt's Avatar
For the first to second shift, check the modulator, or just replace it (they are cheap).
The kickdown, check the kckdown switch. Check for 12v at the connector on the trans at full throttle. While it's not running, but ignition on.
Dunenutt is offline   Reply With Quote
Old 10-01-2011, 07:35 PM   #5
jdheff1982
The fluid and filter were replaced 2 months ago.
The gear selector is still intact, just the clip won't hold.
I will definitely have a look at the kick down switch and solenoid.
