Brake line fittings
Anyone know where to get the fittings that go on the brake lines that are bigger thread outside dia. with a smaller inside dia.? I hope that made sense to people. I am replacing brake lines and am tired of reusing the old fittings that are different size than what comes on the new tubing. I know I have seen them somewhere but can't remember where. Thanks
#2 | |
![]() Join Date: Feb 2010
Re: Brake line fittings
I was able to get them at the local Autozone, but it took a couple tries to get it right. NAPA would be a better choice if there's one close by you.
Front hardlines are 3/16" with either 3/8-24 nuts, or 10mm x .875 depending on the model year. Post- '85 gets sketchy, and could be either size, or even have both sizes on the same truck. Rear lines are 1/4", but I wasn't able to source the correct flare nuts on short notice and had to re-use the old ones. |
Try Carquest...
67-72 parts collector,…
![]() Join Date: Nov 2002
