Old 10-01-2011, 06:33 PM   #1
MikeJones16
MikeJones16's Avatar
Alternator wiring
Which ones of these wires is supposed to hook up to the battery? And it hooks up to the negative side correct?
MikeJones16 is offline   Reply With Quote
Old 10-01-2011, 06:47 PM   #2
68panelman
68panelman's Avatar
Re: Alternator wiring
They both go on the alternator. plug and threaded terminal.
68panelman is offline   Reply With Quote
Old 10-01-2011, 06:48 PM   #3
MikeJones16
I know they both go on the alternator but which one goes to the battery? Like the other end. my battery isn't being charged, alternator checked out fine. Realized, I have my one red power cable going to the starter, and only one ground going to the frame.
Old 10-01-2011, 06:52 PM   #4
68panelman
68panelman's Avatar
The red one going back to the starter puts the charge back to your battery through your positive lead going to the starter.
Old 10-01-2011, 06:54 PM   #5
MikeJones16
So I should tie it into the power cable down at the starter? Or put a terminal on the end of it and just have it touching at the starter?
Old 10-01-2011, 07:00 PM   #6
68panelman
68panelman's Avatar
That depends if your harness is messed with. Alternater wires go to the voltage reg, then feed to your starter and distributor.
Old 10-01-2011, 07:03 PM   #7
MikeJones16
Where can I find this regulator? Its not like under the dash or anything is it?
Old 10-01-2011, 07:07 PM   #8
68panelman
68panelman's Avatar
Should be on your rad support, driver side
Old 10-01-2011, 07:09 PM   #9
MikeJones16
ahhhh....
It's most likely not there anymore. frame off restoration.
Is it a bad idea to just wire it without the regulator? or, can i pick up a regulator locally?
Old 10-01-2011, 07:15 PM   #10
68panelman
68panelman's Avatar
depends on which alternater you have. those wires are for an external voltage regulater. you can get a later one wire alt with internal reg that only joins your poss cable at the batt or starter.
Old 10-01-2011, 07:17 PM   #11
MikeJones16
Do you know if theres any modification I need to make? Should all just bolt up and work? I don't care if the gauges work or not.
Old 10-01-2011, 07:22 PM   #12
68panelman
68panelman's Avatar
The alternaters are have the same mounts. If you go with the internal reg type alt, I would trace back your existing wires and remove to keep down the clutter and single wire the new one to battery or starter.
Old 10-01-2011, 07:36 PM   #13
MikeJones16
As long as i can get driving again. I can slowely work on it.
Thank you soo much for the help.
Old 10-01-2011, 07:41 PM   #14
68panelman
68panelman's Avatar
Glad to help. Good luck with your truck.
