10-01-2011, 09:46 PM | #1 |
starter problems
hi guys I have a problem with my truck, when I connect the battery the starter starts to operate with the key off ... in the morning I replace the ignition switch, but does the same thing when I connect the battery ..... I need help haha... anyone can post pictures of the solenoid because I think my truck does not have..
1986 chevy cheyenne,350,4 speed manual trans,3.5/6 drop 1991 mazda navajo,17" svt's,4x4,5 speed manual |
10-02-2011, 01:02 AM | #2 |
Re: starter problems
The starter solenoid is attached to the starter itself. If you were to look at the starter from underneath, you would first see the starter itself, then on top, the solenoid.
I would check the connections on the solenoid. Sounds like to me, something is jumping the 2 terminals, causing the starter to run. You should have the wire from pos. battery and a pair of red wires connected to a loop going to largest terminal. The smaller terminal is for the other wire coming from alt wire harness.
Project and Truck Specs: http://67-72chevytrucks.com/vboard/s...d.php?t=483381 |
10-02-2011, 01:30 AM | #3 |
thanks buddy I was looking for a solenoid similar to ford cars haha, tomorrow I will check the wires, but if all is well what is failing is the solenoid?
10-02-2011, 03:14 AM | #4 |
Smack it with a hammer..your solenoid is stuck.
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
10-02-2011, 08:24 AM | #5 |
If you smack a solenoid with a hammer, you get a busted solenoid.
10-02-2011, 02:06 PM | #6 |
Moderator
Yup. Had a farm truck do this. It's hung up. Don't hit it with a hammer unless you can afford loosing it as a core.
10-02-2011, 05:42 PM | #7 |
Depends on how hard you hit it
