10-01-2011, 11:00 PM | #1 |
Baby won't start
Restoring my 67 LB and bought a new battery today. It started ok about 5 months ago (taking a while to restore it!). Replaced ignition switch with new. Hooked up batt and nothing. Removed paint on ground cable at alt and still nothing. Put screw driver to starter and got sparks. Any ideas? I mean it's not turning over, clicking, anything. It's like theres not even a batt hooked up except the sparks I got from the starter. Please help!
Thanks, Flashdad
'67 Chevy C10 '68 GMC PU '98 Turd F150 4x4 (I think it may be a chevy under the logo it's such a good truck) '10 Mustang "Life's tough - it's even tougher if you're stupid." John Wayne |
10-01-2011, 11:18 PM | #2 |
Re: Baby won't start
I was going to suggest neutral safety switch but looks like you have a manual so no go there.
What have you changed in those 5 months? When you put the screwdriver to the starter did it turn over? Man I hope you had that thing in neutral when you did that, gives me the chills. Not calling you stupid, just thinking of all the stupid things I have done... Have you verified that the battery is fully charged? A few sparks can be caused by a couple volts.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
10-01-2011, 11:23 PM | #3 |
The only thing I changed was the ignition switch (bought new one). I've repainted everything in the engine compartment and was thinking maybe not getting ground. It's on blocks without wheels, so not an issue...even though it was in neutral. I even tried turning on the heater (key on and heater control to full) and nothing. I'm thinking it's somewhere in the ignition, but not sure how to check stuff with a volt meter or whatever.
10-01-2011, 11:29 PM | #4 |
Also, battery is brand new, checked the fuses (all good), replaced ground wire with new and inspected starter wires - no issues there as far as I could tell. What else can I check to narrow where the problem may lie?
10-02-2011, 12:52 AM | #5 |
Look at the small wire running from the + terminal. You may have a burned fusible link, or its not hooked up.
You say it acts like no battery so I'm guessing no lights, horn, or anything. |
10-02-2011, 01:08 AM | #6 |
Tasty Cakes!
This is what I was thinking. The little wire from the + has a fusible link in it and runs to a little "distribution" block on the pass. fender. Pretty much everything depends on that one wire!
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
10-02-2011, 04:57 AM | #7 | |
Everything goes dead. Still happens every once in a while. When it does, I turn on the headlight switch and wiggle the wires at the distribution block until I see my lights come on. Then it fires right up. Once spent over an hour in a parking lot trying to jump start, beating on the starter, even swapping batteries. One little wire can create a lot of headaches. Check the distribution wire(s) and fusable link. |
10-02-2011, 07:30 AM | #8 |
If it isn't the little wire and the starter just sparks when you jump the solenoid you could just have a bad starter.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
10-02-2011, 07:59 AM | #9 |
Junior Member
You said you changed the ignition switch, maybe it is a bad one. Did you change the switch or just the tumbler setup?
You can disconnect the wires from the back of the switch and with a voltmeter or test light see if any of them are hot pretty easy, this will tell you if there is power coming from the battery.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
10-02-2011, 10:26 AM | #10 |
I would say ign. switch also. Did your old one work? If so unplug from the back of the new one and plug the old one back in (with it just haning there) and give that a try.
10-02-2011, 10:54 AM | #11 |
I will try all of the above. I know I've got the inner and outer fenders off and that junction block is just hanging there. I had my son ground the block and tried it but still no go. I'll go out and check the wires and and the ignition with my little meter and let you know the results.
10-02-2011, 11:54 AM | #12 |
ok, first off, there is no wire on the positive going to the starter. the junction block is on the drivers side and has a red wire going to it from the wire bundle that has the headlights. the red wire goes into the junction box and terminates, then there is a blue wire going out from the junction box and it is cut off at the end without exposed wires. I'll get somke pics when I go back out.
10-02-2011, 12:43 PM | #13 |
Checked old ign switch - same result. Checked the ign plug resistence with the multimeter: results - brown/white wire (top of plug) 7 to 8, purple - 3, pink - 3, green - no change like the meter wasn't connected, brown - 40. So I'm gettin resistence, but what does this indicate? I'm an electrical tester virgin and still trying to learn how to check this crap. The positive cable from batt to starter is good (zero), the two wire going to solenoid is good as well. See pics below of junction box, starter and regulator.
hard to see but junction is in the middle of pic with the two wires going into it with the dead end blue wire laying on top. Any help will be greatly appreciated! I'm so fracking close to finishing this project and don't want this to hold me up.
10-02-2011, 02:00 PM | #14 |
That is not your junction block it is your voltage regulator. There should be a block on the passenger fender near the battery, it is basically one bolt with the insulator between the bolt and the fender.
IIRC the positive terminal on the battery should have two wires leaving it, one huge one going to the starter and a second smaller one going to the block on your passenger fender. Do you have both those wires?
10-02-2011, 02:07 PM | #15 |
You have to have a hot wire from the battery going to the junction block in order for your switch to work.
10-02-2011, 04:14 PM | #16 |
Yeah, plugged blue dead end wire from junction box (pic 1) into posi batt cable and it turned right over. Pic of regulator was included (pic 2) just for reference. Turning over now, but not starting. Gas going to filter but not into carb. Tried blowing through fuel line into carb and it's not getting through. Guess I'll have to pull and tear carb down. Thanks for all the help - maybe I'll still stay on schedule! Thanks again, guys. I appreciate it. Flashdad
