Old 10-01-2011, 11:58 PM   #1
ryans69chevy
Tailgate question
How come some trucks came with the woodgrain lettering on the tailgate and some came with the lettering actually stamped into the tailgate and painted white? Was it for some years they did one way and then switched for the next couple years?
If someone can explain to me the reason why so I can learn a little history and I'm trying to decide what way I should go when I get a new tailgate, if I should get a smooth one then put that woodgrain lettering band on or if I should get a stamped chevy tailgate and just have them painted white which is how mine is right now on my 69.
Thank you!
ryans69chevy is offline   Reply With Quote
Old 10-02-2011, 12:06 AM   #2
70cst
70cst's Avatar
Re: Tailgate question
The trucks with the options such as the CST package had the band on the gate. Trucks w/o options had just the letters stamped into the metal. If I am wrong others can add more correct info.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 10-02-2011, 01:06 AM   #3
They all had the letters stamped in the tailgate. If you got the higher end wood grain or black trim, they just screwed it on top of the stamped gate. Far as I know the only way to get a tailgate with the letters stamped in now days is to find an original gate somewhere as GM stopped the aftermarket folks from making the stamped ones.
Old 10-02-2011, 01:13 AM   #4
VA72C10
VA72C10
VA72C10's Avatar
except keyparts and goodmark make a stamped chevrolet gate for around $350 plus shipping that's as heavy as an NOS gate and fits almost as good...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-02-2011, 01:21 AM   #5
That is good to know. I was not aware anyone was making them again.
Old 10-02-2011, 01:26 AM   #6
71sierragrande
Petroleum User
71sierragrande's Avatar
LMC has the stamped gates for $330.
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 10-02-2011, 11:16 AM   #7
68 IRON
68 IRON's Avatar
Where is the fit off? I know the weight is about the same and feels good and sturdy.
68 IRON is offline   Reply With Quote
Old 10-02-2011, 11:23 AM   #8
VA72C10
VA72C10
VA72C10's Avatar
The top edge profile is slightly off from what I've seen. Not a huge deal but not exactly correct either. Also, the reproduction ones have nicer spot welds than the originals...again, not a big deal to me but someone wanting a 100% resto would notice....just like the pinches on the top two corners of a stock rad support that aren't there on a reproduction
Old 10-03-2011, 09:43 AM   #9
chopnchaneled
chopnchaneled's Avatar
On mine the socket where the tail gate hinges was a lot larger in diameter and you have to cut it on the top and make it smaller to raise the gate to make it flush with the top of the bed.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 10-03-2011, 01:00 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
I think that's a common issue on factory trucks also...I've seen a couple of original paint trucks with that same issue...we have to remember quality control on our old pickups wasn't what it is today...my 71 blazer was like that with both the original gate and the repop...
Old 10-04-2011, 10:01 AM   #11
ryans69chevy
So when I look for a tailgate I want to get one with the letters stamped and then I can buy a woodgrain stamped panel as well to go above the stamped letters on the tailgate? Does anyone have any pics of how this is suppose to look? It seems to me that the only tailgates I've seen is either 1. stamped or 2. no stamped, but has a woodgrain panel to take the place.
Old 10-04-2011, 11:57 AM   #12
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
#2 would be stamped as well, just covered up with the aluminum + woodgrain panel. With the woodgrain in place, you can't see the stamped letters from either side.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 10-04-2011, 12:37 PM   #13
VA72C10
VA72C10
VA72C10's Avatar
if you get a keyparts/triplus non-stamped gate you will save around $100+. They are exactly the same as the stamped gate other than the stamped letters....
I have seen some brand non-stamped gates that will fold in the middle if you sit on them so that's why I can only recommend the keyparts/triplus gate at this time....
Old 10-09-2011, 08:48 PM   #14
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
so chevy NEVER made a non-stamped tailgate??? All ones without the stamp are not original?
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline   Reply With Quote
Old 10-09-2011, 09:05 PM   #15
VA72C10
VA72C10
VA72C10's Avatar
correct. Every chevy/gmc came with a stamped gate...even if the applique is on the gate it's stamped under it.
