Old 10-02-2011, 01:56 AM   #1
rubberbandit
Active Member
rubberbandit's Avatar
converting to low hump
Anybody know where I could find a low hump for a 72 chevy cab? I know there are some companies that sell entire floor pans but I'm just trying to replace my bolt in high hump with a low hump. I understand that its part of the floor in the low humps but a replacement piece, bolt-in or not, would be much easier than finding and cutting a low-hump cab
-Chad
'72, C10, SWB, fleet, 4L80E, 406sbc, EFI, TruTrac Blackfoot
'69 C20 Suburban, PB Dropmember, 3rd row, LS3 6.2L, 4l80e, rear A/C, Dakota Digital HDX Babe: The Blue Ox
rubberbandit is offline   Reply With Quote
Old 10-02-2011, 07:13 AM   #2
hugger6933
Re: converting to low hump
I'm sure there are many poeple here would trade you[including me] a low hump for a high hump. Are you converting from a high hump to a low hump? I have two cabs that I will be doing the opposite.
hugger6933 is offline   Reply With Quote
Old 10-02-2011, 10:10 AM   #3
Tim Christian
Tim Christian's Avatar
Don't know what your reason is but if you already have a high hump it would be cheaper and a much cleaner looking job just to bolt a high hump back in. But if that won't work for you. You would have to find a good used low hump cut it out and weld it back in your truck. Nobody reproduces these so you would have to go used.
Tim Christian is offline   Reply With Quote
Old 10-02-2011, 11:42 AM   #4
WETOWM
I have a low hump cab that i am converting over to a high hump if that would help you at all??
WETOWM is offline   Reply With Quote
Old 10-02-2011, 07:16 PM   #5
rubberbandit
Active Member
Okay, here's my story:
When I bought my truck the PO told me that it had a stock 350/th350 in it. After I got it home I ran the numbers of the engine and transmission and found out that both were out of a 1974 Chevy car. It was actually a 400(sbc) and a th400. I am rebuilding the engine and will still be using the TH400. I am doing a from off resto and, after looking at pics of other trucks, realized that there are different sizes of tranny tunnels (low hump and high hump).
I realized that mine is a high hump. I can tell that it was a low-hump at one time but the floor has been converted (cut out and drilled for a high-hump). I am putting a bench back in the truck and would like more leg room in the middle.
In your opinions, is this worth it? I can't imagine it would be difficult to put a low hump replacement back in. Are there any advantages to having a high hump?
If I did make the conversion I would like to keep the high hump cover in case I decided to go Big block in the distant future. What do you guys think I should do? Does anybody have a replacement piece (and a price) they would be willing to ship to 89145?
All comments welcome. Thanks
-Chad
Old 10-02-2011, 08:08 PM   #6
sboris
sboris's Avatar
You don`t lose much leg room low to high hump and if theres
any chance at all your going BB, to me it wouldn`t be worth
monkeying with. My .02
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 10-02-2011, 10:59 PM   #7
ItsRandy
ItsRandy's Avatar
I've got a big block in mine and I have a low hump...works great.
ItsRandy is offline   Reply With Quote
