10-02-2011, 11:44 AM | #1 |
High hump change over
What is the best way to convert a low hump cab to a high hump so it looks facyory ??
10-02-2011, 05:22 PM | #2 |
Re: High hump change over
I got a high hump from a donor cab, it unbolted, then set it over the low hump and traced the outline and the bolt holes. I then made a card board template of the flange and set it inside the outline I traced on the low hump. I traced this template and cut the inside line with a cut off wheel, drilled out the bolt holes, welded some nuts to the underside and bolted the high hump on. It looks pretty good in my opinion.
1969 4x4 Nothing beats a good rock drill and some dynamite |
