04-13-2003, 11:37 PM | #1 |
Core Support Help ????
Help!!!! I am reinstalling the Radiator Core support on my 1969 C/10, I've had it off for quite some time and have forgotten how the Washers and spacer are installed to the Frame Rails. Does anyone have any photos of how they go back, our the ability to explain it would be greatly appericated, Thanks
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
04-14-2003, 12:08 AM | #2 |
This ought to help. Ran out to my shop at 11:00 PM to get this.
04-14-2003, 12:42 AM | #3 |
its all about the +6 inches
Interesting, that looks nothing like what was in the Longhorn's front clip.
Well, it is close, a couple of the bushings are almost an inch tall on mine, and there is a metal sleeve that goes into it on mine. |
04-14-2003, 12:49 AM | #4 |
Oops, I just noticed - this diagram is up to '68. Sorry, I tried to help.
04-14-2003, 07:23 AM | #5 |
From the top of core support
Carriage Bolt Square Washer Under The Support between support and frame approx. 1" thick pad with steel insert has a ridge on bottom middle that extends down through hole in frame Steel sleeve inserts through center of this and into pad under frame Under the core support frame bracket Pad with beveled edge beveled edge points down steel insert inserted in pad above frame inserts into this pad also Steel Round Washer Nut Thats the order they go in from top to bottom the above picture is for 1960-68 mounts. GMCPaul |
04-15-2003, 10:19 PM | #6 |
Thanks for the information, The previous owner of my truck had used 67-68 type mounts, I have corrected this and went back with the proper type mounting, everything went on fine. The truck should be back on the road next weekend.
