Old 10-02-2011, 08:06 PM   #1
Laid_Out_50
Laid_Out_50's Avatar
Steering Kit
A couple months ago I was online surfing around and i came across a magazine article on a steering kit for classic Chevy trucks that allows you to use the stock column with a rack and pinion. Did anyone else come across this article I cant remember who made the kit
Laid_Out_50 is offline   Reply With Quote
Old 10-02-2011, 09:57 PM   #2
Rude Dude
Rude Dude's Avatar
Re: Steering Kit
It was RB's they have sinced closed up shop
Rude Dude is offline   Reply With Quote
Old 10-02-2011, 11:16 PM   #3
cajundragger
Re: Steering Kit
column savers
cajundragger is offline   Reply With Quote
Old 10-02-2011, 11:42 PM   #4
Laid_Out_50
Re: Steering Kit
Thanks Guys
Old 10-03-2011, 01:00 AM   #5
parkwood
parkwood's Avatar
Re: Steering Kit
check out www.ecklerstrucks.com kit cost $75 bucks.. I've done three or four not using this kit but this looks like a clean set up..
parkwood is offline   Reply With Quote
Old 10-03-2011, 02:01 PM   #6
OrrieG
OrrieG's Avatar
Re: Steering Kit
I thought there was a place where you could just buy the bearing? Or if you live in a metro area you could take the shaft OD and column housing ID and a good bearing supply counter guy will set you up. We did it all the time at the papermill for custom shaft applications. There is a thread with pictures too floating around the site.
OrrieG is offline   Reply With Quote
Old 10-03-2011, 08:03 PM   #7
FFredo
Re: Steering Kit
Sorry to high-jack with a noob question, but can a guy use this modification and keep the stock axle/steering set up and add a R&P?
FFredo is offline   Reply With Quote
Old 10-03-2011, 08:42 PM   #8
parkwood
parkwood's Avatar
Re: Steering Kit
What i've done on a couple is take a carrier bearing and cut the threaded part off and weld that to the column, the inside ID is 3/4... but a good bearing of any kind will work.. had a friend use the outer bearing for a brake drum once.. what every fits inside the column tube ...
