10-03-2011, 12:40 AM | #1 |
Poor cab support fitment
Hi all,heres a few pics of my problem.The first 2 are the drivers side,the second 2 are the passenger side.Im not sure there is supposed to be that wide gap at the rocker/cab corner I was told this is normal and it is generally filled with seam sealer.The drivers side is all around poor fit.Maby its poor cab corner fitment ?
Let me know your thoughts please. Thanks, Ed |
10-03-2011, 10:01 AM | #2 |
1961 crewcab
Re: Poor cab support fitment
looks like your drivers side lower rocker is bent a little at the back, sealing up the gap...
you might want to do 2 different things, seal it up completely so no dirt/water can get in and rust it out, or make the gap a little bit bigger so that dirt will not have a chance to build up in there.... most originals that I get into that are not rusted, are packed full of dirt.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
10-03-2011, 08:10 PM | #3 |
1 thing at a time is progress.
I went thru all of my pics to find you a good one. I didn't find a good one for comparison, but I found this one.
It looks like the drivers is but welded to the inner rocker. It's hard to tell, but I don't see a flange like on the pass side. I wouldn't be too concerned about the gap along the bottom of the support where it meets the rocker. The gap like Jon said will definately keep stuff from building up.
Alan
Philippians 2:14-16 |
10-03-2011, 08:21 PM | #4 |
I did seam seal as many joints as possible. No, it's not factory. The factory's plan for corrosion protection didn't work very well. I also used an inner rocker spray that is a waxy substance to help on the inside. I also use weld thru primer on all the welds.
Alan
