10-03-2011, 10:23 AM | #1 |
Need Some advice
Its a 71 c10 350 pretty much stock motor except for intake and carb. Driving home last night it stalled at a red light, and when I started it back up it started running rough and popping through the carb. I am thinking maybe the timing chain is worn out, it ran good all weekend.
10-03-2011, 10:40 AM | #2 |
Re: Need Some advice
Popping through the carb is usually an exhaust valve not opening. Maybe a broken rocker, bent push rod, collapsed lifter? Pull the valve covers and check it out.
10-03-2011, 10:46 AM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
Have you tried it since it cooled off? might be a coil.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-03-2011, 10:56 AM | #4 |
pulled the valve covers last night everthing looks good. It wont idle either as it sits there idling it is popping and then stalls
10-03-2011, 12:33 PM | #5 |
Could also be a broken intake vale, sometimes they will lose a chunk of the valve. I had a Dodge van do it back in 74. The valve looked a pie with a piece missing. Popped back through the intake and ran like crap, worse than a Dodge usually does.
Not saying it is, but it might be worth checking. Also put a timing light on it and see if it's holding timing or if the mark is dancing all over the place. Good luck Dan |
