10-03-2011, 12:12 PM | #1 |
1957 Deluxe Heater
I have a 1957 deluxe heater that I am re-doing for my 1957 Cameo truck. My questions is this. What COLOR should the heater box and fan be and what is a good source for a rattle can spray paint that would be close?
I want it to appear as original as possible. Thanks in advance for your replies. |
10-03-2011, 01:20 PM | #2 |
Re: 1957 Deluxe Heater
Not sure how perfect you need to be but I'd use a Rustoleum hammertone gray
Posted via Mobile Device |
10-03-2011, 03:09 PM | #3 |
The rustoleum Dan mentioned is what I used also. Well pleased with the color.
10-03-2011, 03:40 PM | #4 |
10-04-2011, 04:00 AM | #5 |
if ya really wanna play your cards right - look hard enough on the heater box and you should find a date of manufacture - you can highlight that in white - subtle but classic
10-04-2011, 04:00 AM | #6 |
dan you truck is really lookin nice --- very good work
10-04-2011, 11:35 AM | #7 |
Oh thanks. I hardly get any time to work on it, then I get to it for a day or two and get frustrated when "stuff" gets in my way for another week or two.
Right now its blocked into my driveway by my camper and boat so I can't drive it. Besides the cluster is out of it and I can't start it with the oil line disconnected. So, I'm just piddling at it. Throwing more primer at it. Cleaning up the interior some, etc. |
10-08-2011, 03:43 AM | #8 |
Jim Carter truck parts has the info and paint
10-08-2011, 11:57 AM | #9 |
Hey lackey, whatever happened to our "Before" picture? You owe us one! lol
10-08-2011, 12:20 PM | #10 |
http://67-72chevytrucks.com/vboard/s...d.php?t=441585
one of my pics shows the hammertone pretty good, but it's not green as it looks there. |
10-08-2011, 04:39 PM | #11 |
here you go..."BEFORE"
10-08-2011, 10:40 PM | #12 |
That doesn't look too bad. Is there any rust-through? Looks like you could just give it a nice sanding and rattle can it hammertone. I would. I'd prolly clear it too, but not sure if I'd use gloss or a semi gloss. I mean, you want your heater to look nice but do you really want to call attention to it?
10-09-2011, 04:53 AM | #13 |
no rust, whatsoever. I am excited about taking it apart an rebuilding it!
10-09-2011, 05:33 AM | #14 |
10-09-2011, 12:37 PM | #15 |
if i am not mistaken i think you are missin some pieces on your control valve
10-10-2011, 05:06 AM | #16 |
Daze57
Can you offer details about your comment? |
10-10-2011, 05:12 AM | #17 |
Thanks for the pics TMOBILE!!!
10-11-2011, 03:05 AM | #18 |
rdlackey
if you look @ tmobles pictures - the black case pictures - it shows a complete water control valve . your whole bottom half is missing - its the part that opens and closes the water valve - i had the same thing when i took mine apart .- bought a new one from one of these vendors -cant remember the cost - but after replacment i had all he controls working correctly - compare the pics . will be glad to assist if ya need help. |
10-11-2011, 07:32 AM | #19 |
DAZE57
Is this what you are referring to (Water control valve)? On mine, it is attached to the heater core "inside" the heater box. In this picture the control cable IS NOT connected at this time from the control lever. Randy |
10-11-2011, 02:42 PM | #20 |
Those are usually missing because direct replacements were hard to find. I had the same problem in the 80's and ended up getting a core that fit, modified the in/out hoses and put an inline control valve in place.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
10-12-2011, 02:46 AM | #21 |
rdlackey
from lookin @ your earlier pictures i did not see the control valve - you do have all the parts then;and looks to be in pretty good shape .give it and the water hose a good lookin over ;make sure ya aint got no leaks .and lube your operating cables those are really good heaters - and hard to find ! good luck on your build. |
