10-03-2011, 12:22 PM | #1 |
WTB a few Blazer Items
I am looking for a few items for my blazer.
1. Lower body Trim woodgrain (bought) 2. 71-72 Grill insert 3. Some Weatherstripping, have double wall top (Door window to top rubber, top to body rubber, tailgate stuff)(bought) 4. Console emblem (bought) 5. Carpet if anyone has new one they don't want. (pending) 6. Rear Carpet strips (Front and rear) 7. Rear upper Side Panel moldings (bought) 8. 4wd Fan Shroud (bought) 9. Nice Rear Wheel tubs (bought) 10. patch panels: lower kickpanel on passenger side, passenger A pillar, passender B pillar, front half passenger/driver side bedside, passenger/driver side Rocker box reinforcement assembly plate, passenger/driver side rear cab floor support, passenger/ driver side rocker panels. 11. Nice Grill Blue bowtie 12. Year correct roll bar 13. Rear black interior panels 14. rear panel stand offs, all 6, plus 6 angle pieces. 15. Black dash Pad 15 Blazer door reinforcements (bought)
1972 K5 Auto 4x4 factory air 2007 Silverado extended cab Z71 Last edited by Ridnhi; 04-02-2012 at 10:48 AM. |
10-03-2011, 05:37 PM | #2 |
People know me
Re: WTB a few Blazer Items
Here is a link to another thread with what I did for my carpet strips.
http://67-72chevytrucks.com/vboard/s...d.php?t=487060
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
10-03-2011, 11:50 PM | #3 |
bigbad- I like the way those look. Did you have to cut the bed rail at all or did it just fit into place? And how much do those chrome bed strips cost. Is it easy to buy just one? Thanks.
1972 K5 Auto 4x4 factory air 2007 Silverado extended cab Z71 |
10-04-2011, 12:04 AM | #4 |
People know me
The 60-66 one I got out of LMC, it was $20 for the PSS-(polished Stainless Steel) they sell them individually and I am not sure on the front one, like I said I got mine at a yard sale. You may be able to find a cheaper one, the link I posted was just an example.
I did have to cut down both of them. I used a sawsall, but a hacksaw would cut it easy too.
10-04-2011, 12:03 PM | #5 |
I've got some leftover weatherstripping, for a double wall top though.
If you are interested: #38-6968 Side Window Rubber (I have both of these) LMC = 39.95 ea Sell = 32.00 ea #38-6969 Hatch Glass Rubber LMC = 49.95 Sell = 42.00
1972 Blazer - Bronco Orange - In the werks http://67-72chevytrucks.com/vboard/s...d.php?t=323444 1991 F250 - Hunting truck w/ Detroit rear locker, ARB front locker, front and rear winches .... and more.... 1997 Grand Cherokee - fun jeep - Detroit rear locker, ARB front locker, front winch, 411 gears, lots of lights ;-) 2004 Hot Rod DuraMax - Dnyo'd at the wheels with 525 HP and 1100 lbs torque.....mustang killer. |
10-04-2011, 10:06 PM | #6 |
I have a double wall top, but I don't need the Hatch Glass Rubber or the Side window rubber for my top. mines in good shape. Thanks on the help though
10-17-2011, 10:41 AM | #7 |
ttt
10-17-2011, 10:21 PM | #8 |
People know me
I have the complete set of woodgrain moulding off of my blazer, It is not perfect by any means and the previous owner drilled a couple extra holes in it when some of the clips broke, but it has plenty of character if you are interested. I have to pull it out of the attic.
10-18-2011, 09:27 AM | #9 | |
11-06-2011, 11:33 PM | #10 |
ttt
01-17-2012, 01:47 AM | #11 |
ttt
02-16-2012, 12:18 AM | #12 |
ttt
02-16-2012, 07:46 AM | #13 |
Here is a set of the standoffs if interested. $45.00 shipped to you
02-16-2012, 02:38 PM | #14 |
Thanks, they look nice but I'm going to try to find a set for around $30-$35 shipped.
02-16-2012, 06:01 PM | #15 |
One of the things to remember on the rear panel brackets is that there are 6 "L" brackets that you need and the two top chrome strips that the top of the panel slip up into, in addition to the 6 standoffs. The "L" brackets go on the floor in back of and in front of the wheel tub and most importantly, the back of the panel screws to an "L" bracket mounted on the rear box post. Without these brackets, the panel will have nothing to fasten to at the rear up and down and the panels will push in along the floor. If you are looking for a complete set including the upper chrome strips they will go for significantly more than $35 shipped. The photo shows the 2 screws vertically and horizontally that the panels fasten to.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
02-16-2012, 07:18 PM | #16 | |
02-16-2012, 08:51 PM | #17 |
You are welcome. Wish I had something to help you out with in your quest. The "L" brackets are fairly light gauge so you could probably get some thin steel or aluminum angle at a local hardware. I'm sure that yours will be outstanding. Keep us posted.
03-01-2012, 01:43 PM | #18 |
back to the top
03-30-2012, 03:21 PM | #19 |
ttt
03-31-2012, 04:27 PM | #20 |
I accidentally bought black cst carpet for my non cst blazer. I cut a quarter sized hole for the 4wd shifter on the hump. I'll let it go for 250 plus shipping if you're interested. Thanks!
Posted via Mobile Device |
04-01-2012, 01:03 PM | #21 |
04-01-2012, 11:19 PM | #22 |
What is different about the CST carpet? I have a 4wd and 4spd. I'm guessing the hole you cut wouldn't be an issue. My blazer is not a CST. Would it still work. Is this a full carpet set, Front and rear? does it cover the rear wheel wells? What do you think shipping would be?
04-02-2012, 09:15 AM | #23 | |
04-02-2012, 10:43 AM | #24 |
Yes, I will be running rear interior panels. Im interested, if you would get a shipping quote, Marion, IL 62959. We have a greyhound station here too if you would like to see what that would cost. Thanks, Eli
04-02-2012, 11:18 AM | #25 |
Based on rough estimates, it looks like it will be about $50 to ship. If it's more I'll cover the extra, and if it's less I'll refund you the balance?
