Old 10-03-2011, 01:08 PM   #1
JORGIE95961
Whats the best /cheapest way to seal drip rail?
I was thinking about heating up soem ofthe dynatron seam sealer i have tomake it flow smoother.. but im not too sure.. any advice?
JORGIE95961 is offline   Reply With Quote
Old 10-03-2011, 09:04 PM   #2
trev1
Re: Whats the best /cheapest way to seal drip rail?
I just sealed it with plastic body filler. Thats what it seemed to be originally for my 69 Cst C-10. I dont know if you're doing just a quick fix or if you're doing a more complete resto, but I didn't have much trouble and it sealed it pretty well. Hope it helps.
trev1 is offline   Reply With Quote
Old 10-03-2011, 10:11 PM   #3
Lee H
Lee H's Avatar
Caulking, (you did say cheapest).
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-03-2011, 10:37 PM   #4
jamesi20
jamesi20's Avatar
cheapest and best usually don't go together very well...if you want to do it right,get the 3M seam sealer and be done with it.
jamesi20 is offline   Reply With Quote
Old 10-03-2011, 10:40 PM   #5
late68
late68's Avatar
Thumbs up Re: Whats the best /cheapest way to seal drip rail?
I second that!
1968 C10 SWB Dropped 5 in tha back 3 in tha front
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902
late68 is offline   Reply With Quote
Old 10-03-2011, 10:58 PM   #6
mm1077
Active Member
mm1077's Avatar
I used the maxim self leveling seam sealer #824 for drip rails. It was like $37 after shipping and didn't require any special application gun.
mm1077 is offline   Reply With Quote
Old 10-03-2011, 11:16 PM   #7
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
A trick my bodyman taught me is to have a little cup of thinner (and lots of rags handy), dip your finger in the thinner and smooth it out like you would with caulking. Works pretty good (if you're good at that sort of thing).
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 10-04-2011, 06:42 AM   #8
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
It's not cheap but I just got some POR 15 seam sealer that I'm going to give a shot on my wrecker project.
The 3-M and similar seam sealers ALL crack sooner or later and in my case(s), it's always sooner!
Hoping this stuff will be the magic cure but we'll see...
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-04-2011, 07:19 AM   #9
Cheapest isn't best. Use the two part stuff. I used the 3M in a caulk tube and it has cracked,although still pliable. I smoothed it out with thinner and rags as C10-Driver suggested. It may be just the paint cracked. I have to check closer. It takes a long time to cure being applied thick and maybe I painted too soon.
Old 10-04-2011, 11:22 AM   #10
camrycurt
camrycurt's Avatar
What about Eastwood's Seam Sealer? Has anyone used that?
Does it fall into the same category as the 3M and similar sealers?
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 10-04-2011, 12:53 PM   #11
extd56
extd56's Avatar
It is a good question and would also like to know which one will hold up the longest.
extd56 is offline   Reply With Quote
Old 10-04-2011, 02:52 PM   #12
slikside
slikside's Avatar
subscribed.
slikside is offline   Reply With Quote
Old 10-04-2011, 03:12 PM   #13
AirSpeed
AirSpeed's Avatar
When I did mine I used some sealer I found at NAPA, the tube looked like it had been around awhile but I used it anyway, as I used it I could see a few air bubbles in it, I should have stopped right there but I didn't. As soon as the weather got warm I noticed the entire gutter had inflated, the sealer looked like a small innertube. I ended up having to grind the gutter out again, it wasn't that fun the first time but grinding out all that soft sealer was pure Hell! The point is when doing something like that it's best to do it right the first time! Don't go cheap if you want it to last! Make sure you grind out every last bit of surface rust you can get to and treat what you can't with some sort of rust converter. It sucks to have to do the same job twice!
AirSpeed is offline   Reply With Quote
Old 10-04-2011, 03:27 PM   #14
VA72C10
VA72C10
VA72C10's Avatar
good info here...anyone have a long term solution that's worked?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-04-2011, 08:32 PM   #15
bcutt
bcutt's Avatar
Best stuff you can get IMO.. This is 2 part epoxy seam sealer that is self leveling. I paid $20/tube on sale but its normally $30 or so. Uses a standard caulk gun to apply. I recommend putting it on over some good epoxy primer.
http://www.evercoat.com/productDetail.aspx?pID=257
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see."
- Thomas Jefferson
72 C10 SWB "Work in Progress"
bcutt is offline   Reply With Quote
Old 10-04-2011, 08:35 PM   #16
jondancer
I think there is another thread on this, I'd like to know the best not the cheapest.
jondancer is offline   Reply With Quote
Old 10-05-2011, 01:28 AM   #17
VA72C10
VA72C10
VA72C10's Avatar
Anyone else used the evercoat? Or have long term feedback? Sounds like a winner on the best and still cheap at this point...
Old 10-05-2011, 02:18 AM   #18
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
i used 3m 2k self leveling seam sealer. i even have the gun for it. you can come check it out.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 10-05-2011, 10:10 AM   #19
bcutt
bcutt's Avatar
I did a lot of research on this board and other Auto Body forums before I went with the Evercoat. I think most professional paint/body men would agree that for the price and ease of application you cant do any better than this stuff. Of course others will say go with the 3M stuff but most their 2-part sealer requires the special mixing gun which unless you run a shop is not worth the investment. This stuff is leaps and bounds better than what GM used from the factory, I'm only 28 and this stuff will probably out last me..
- Thomas Jefferson
Old 11-16-2014, 04:06 PM   #20
67chevy1
67chevy1's Avatar
subsribed
67chevy1 is offline   Reply With Quote
Old 11-28-2014, 07:09 PM   #21
desertnick69
desertnick69's Avatar
So what Evercoat product did you use?
desertnick69 is offline   Reply With Quote
Old 11-28-2014, 07:50 PM   #22
Redline novdog
Redline novdog's Avatar
I'm in My cabs a leakin'
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 11-28-2014, 09:16 PM   #23
57taskforce
All about them K’s
57taskforce's Avatar
I've had good results with lord fusor self leveling seam sealer. Got if from autobody tool mart for ~20 a tube. Uses a regular caulk gun and after 6 years in the drip rails of my '57 it still is holding up well.
Tyler
57taskforce is offline   Reply With Quote
Old 11-29-2014, 08:46 AM   #24
That was back in Oct '11. About two years later I sent to paint my top and discovered that 3M stuff was not bonded to the front lip in spots. It remained pliable still. I dug out enough to get a hold of and pulled it all up in one piece. only had to scrape/grind the thin edge that remained. It was totally wet under there. Fortunately no rust,though. I went to my auto body supplier and they sold me the Evercoat. They claim to be the supplier to the auto industry. Now, a couple years later I am seeing cracks in it. Whatever GM used lasted far more than two years. Both times I went down to clean metal, etch primed, and painted. Also cleaned/prepped properly. I'm going to read through here and see what other good product have worked better
*EDIT: Looks like I'm trying what Taskforce57 used
Old 11-29-2014, 09:51 AM   #25
67swb72klb
67swb72klb's Avatar
I have been using the 3M ultrapro urethane sealer for many years on cars and trucks without problems
inside of the bed on my 67 being the first thing I used it on 20+ years ago and still looks good the stuff sticks to anything too
I think it also comes in a regular caulk tube now
http://www.google.com/url?sa=t&rct=j...,d.cWc&cad=rja
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
