10-03-2011, 01:38 PM | #1 |
Unknow wire
There is wire hanging on the driver side that I'm not sure where it goes. I think it is the temp gauge (its not working by the way) but cant seem to find the place where it connects. Anyone have photos where it connects?
Thanks |
10-03-2011, 01:39 PM | #2 |
Re: Unknow wire
Might want to post pictures.....
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
10-03-2011, 01:45 PM | #3 |
Re: Unknow wire
Here you go.
10-03-2011, 01:50 PM | #4 |
Re: Unknow wire
I'm pretty sure that's your temp gauge wire hanging loose... and since your temp gauge isn't working it's a pretty sure bet! Look on the side of the engine block for a brass looking sensor thats threaded into the block. It should have a flat / blade type connector sticking off the end of it. Simply slide the connector on the end of that wire onto the blade and it'll probably solve both of your issues.
10-03-2011, 01:53 PM | #5 |
Re: Unknow wire
With its location and being green that is the temp sender wire.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
10-03-2011, 02:22 PM | #6 |
Re: Unknow wire
Here is how it looks hooked up on my big block 83:
10-03-2011, 02:27 PM | #7 |
Re: Unknow wire
On my 350 it's in a very similar spot to the BBC above. It's on the driver's side cylinder head.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
10-03-2011, 02:55 PM | #8 |
Re: Unknow wire
Thanks All.
I will check it out. |
10-03-2011, 08:47 PM | #9 |
Re: Unknow wire
Got it... I was thrown off but the way it connected... was looking for a flat /blade type connection where it should go. The way it connects by tucsonjwt picture is that it was a tip slide on connection not a flat/blade type connection.
Thanks again |
