Old 10-03-2011, 05:18 PM   #1
bucannon
Salty Sailor
bucannon's Avatar
Cool Nobody seems to be able to answer this???
okay ive got a LCA issue. will a 3/4 ton arm fit on a 1/2 ton k frame?
my original thread in the 73-87 board shows pictures.
thanks for any help!
http://67-72chevytrucks.com/vboard/showthread.php?t=486659
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 10-03-2011, 06:30 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Nobody seems to be able to answer this???
Are you buildin 1/2, or 3/4 suspension? 2wd or 4wd? I have to ask this, cause most guys see K, and assume 4wd The C is 2wd. A little more info would help....crazyl
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-03-2011, 07:40 PM   #3
bucannon
Salty Sailor
bucannon's Avatar
the truck is a 2wd C-10
okay heres the deal im using lift spindles form a newer body style truck which fit 3/4 ton ball joint, so i just ordered 3/4 lower control arms so they would be new and look fresh under the truck but the LCA shaft will not center up on the k frame because of the tabs that go into the two holes on the LCA shaft...
Savannah, Georgia
Old 10-03-2011, 11:04 PM   #4
bucannon
Salty Sailor
bucannon's Avatar
Savannah, Georgia
Old 10-03-2011, 11:13 PM   #5
BMERDOC
BMERDOC's Avatar
Someone help me here but isn't the 3/4t LCA used to attach the 88-98 spindles/brakes to the earlier trucks because of the ball joint size? I remember reading that on another thread...possibly the FAQ Brake sticky
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 10-03-2011, 11:18 PM   #6
SCOTI
SCOTI's Avatar
Correct. 3/4 ton & larger lower arms have a larger OD ball-joint body which coincidently matches the 88-98 1/2 ton size.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-03-2011, 11:37 PM   #7
bucannon
Salty Sailor
bucannon's Avatar
Cool Re: Nobody seems to be able to answer this???
thats correct.
Savannah, Georgia
Old 10-04-2011, 09:32 AM   #8
SCOTI
SCOTI's Avatar
To your original question, the arms will interchange. I have had lower a-arms from a 68 as well as lower a-arms for an 89 C30 bolted up to the same x-member (same 73-87 x-member in 2 different trucks).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-04-2011, 03:31 PM   #9
bucannon
Salty Sailor
bucannon's Avatar
THANK YOU, i know know that Rock Auto did not properly drill the holes in the control arm shafts.
so looks like ill be getting some local parts store LCA shafts
Savannah, Georgia
Old 10-04-2011, 04:17 PM   #10
bucannon
Salty Sailor
bucannon's Avatar
okay now after looking at the Autozone website i see that the stock photo displays the 3/4 ton LCA shaft with only one hole
WTF???
Savannah, Georgia
Old 10-04-2011, 04:51 PM   #11
SCOTI
SCOTI's Avatar
From what I remember, there's only one locating hole drilled in the shaft & only one dowel that extends far enough from the x-member to make contact.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-04-2011, 05:07 PM   #12
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Call Rock auto, In my experience they have made everything right very fast.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 10-04-2011, 07:31 PM   #13
crazy longhorn
Yup, & the pin is to the back side crazyL
Old 10-05-2011, 03:56 PM   #14
bucannon
Salty Sailor
bucannon's Avatar
so the rear pin is where it lines up and the front dosent make contact?
does anybody have pictures on some 73-87's
Savannah, Georgia
Old 10-05-2011, 05:04 PM   #15
SCOTI
SCOTI's Avatar
Only one pin should be long enough to make contact. That is what positions the shaft/arm.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
