tobins 52 gmc
vintage air install picts
would like to see some picts of a vintage air set up , under the dash and the mounting of the air box. Any problems that you came across and some good advice .Also show how it looks in the engine bay ,your contorls ,everything you got ..thanks Robert
Re: vintage air install picts
This is an older A/C unit cable controled, now it's elect. This is in a '55 chevy.
The completed trucks..
![]() Join Date: Oct 2009
oooooooh. PurDee! Nice work there!
This installed in a '52 Subruban
more shots
last few
I like fewer connections on my hoses
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
Parkwood, What did you make the under dash valence? out of? I love the way it hides the AC unit and provides mounts for the ducts. Need to fabricate something like that in the next few weeks. I'm using the Vintage air smallest universal unit due to firewall set back, etc. Thanks.
#11 | |
#12 | |
P.S the dash looks nice. |
#13 |
![]() Join Date: Mar 2007
I had a lower dash valance made out of steel but I also cut the bottom of my dash flush across the bottom. I also used a vintage air kit. Which was a little tricky with my *****in products firewall because of the set back.
BTW I taught Parkwood everything he knows.....Oh wait maybe it is the other way around.. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#14 |
You're right on name, knew it was called something besides card board.. thanks.. hate to see a guy use a card board box from something i said..
#15 | |
#16 |
Very nice. I was thinking metal also because I want the panel to be dash/body color, but that upholstered look is pretty sweet. I particularly like the way the passenger side goes all the way to the firewall and covers the AC unit.
#17 |
That's hurtful.....
#18 |
#19 |
tobins 52 gmc
all very nice ,thanks guys .Keep them comming ,going to order my unit this week
#20 |
Ok, stupid question, does the "Vintage Air" setup also handle the heater side of things?
#21 |
#22 |
The pictures show in this thread, are those AC only, or are they heat (hense the 4 lines going through the firewall??)
Does the unit grow in size as you add these options? I assume it does for heat since there is a heat exhanger for that as well, defrost is probably only more hoses under the dash and a different switch? |
#23 | |
| Bookmarks |
