Old 10-03-2011, 07:02 PM   #1
72gmcshorty
72gmcshorty's Avatar
help id this trans/transfercase
i have this transfercase still attached to the trans. I waant to sell the entire unit but am not sure what year it is from. The PO "thinks" it was a 2004 but not sure. I found some numbers on a sticker on the transfercase if this helps...
60YS NOBB459922 YS48800
Any help is appreciated
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 10-04-2011, 01:19 PM   #2
72gmcshorty
Re: help id this trans/transfercase
found some other numbers:
263 hdgm
1257 5647
11 08 102 G3
272
any help id year?
1992 Gmc 2wd
Old 10-04-2011, 03:58 PM   #3
biggsteve97
Your transfercase is the NVG 263 HD GM. Which is the New Venture Gear 263 Heavy Duty transfercase mainly used in 2001-2004 Gm 2500HD and 3500HD trucks. It is similar to the NVG 261 t-case but seems to be a stronger design. As for the transmission if it is the automatic and it was behind the Duramax it will be the Allison 5 speed or if it was behind the gas engine it would be the 4L80E, if it is the manual trans it will be the NV4500. Hope this helps.
biggsteve97 is offline   Reply With Quote
Old 10-04-2011, 10:53 PM   #4
72gmcshorty
helps very much. Was told the trans thats bolted to it was a 4l80e but still no sure of the exact year. But at least now i have better description for selling.
1992 Gmc 2wd
Old 10-05-2011, 11:33 AM   #5
72gmcshorty
is there a tag on the trans similar to this that would tell me what it is? (trans is covered in mud)...
1992 Gmc 2wd
Old 10-05-2011, 03:07 PM   #6
biggsteve97
I do not believe there is a tag however GM used to stamp 4L80 in the bell-housings if it is not a removable bell-housing. If it is a 4L80E it does not look much different on the outside than most of GM's automatics, if it is the Allison the trans is large in comparison to any GM automatic and it will have Allison stamped in the side as well as an external spin on filter next to the pan at what would be the drivers side front corner if the trans was in the truck. These are the only two automatics GM used with the transfercase.
