need opinions for rear end
Ive got a triangulated four link set up but im not sure what rear end i want to use. Heres what i got, stock 12 bolt(5 lug) ford 9 inch thats two inches wider and would need a different lug pattern, and adifferent nine inch rear thats under my 35 chevy, its got a posi, 4:11 gears, strange axles already 5x5 chevy pattern. This is the one id like to use, problem is its been narrowed for the 35. I measured it to be 52 inches from flane to flange while the stock 12 bolt is 58(close to it anyway). If i run the narrowed 9 inch, i could just run a larger tire and wheel, i dont care for the pro street look, maybe more of a corvette look. The truck has a step notch and is bagged, would 3 inches narrower on each side be a big deal? i plan to run 18 or 20 inch wheels. what would you do?
ttt
Almost Satisfied
![]() Join Date: Mar 2002
I would use the other 9", have it narrowed and order new axles for it. I would pull the posi out of the 35 and put in this rearend. You might check and see if the axles you have can be narrowed...might save $ from buying a new set.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
tub it and use the short 9"...since you are going to set up the rear geometry anyways
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
custom axles are expensive, the ones in the 9 inch i have are tapered so they cant be cut down, mainly what i want to know is if any one thinks the one out of my 35 is too narrow, i will probably use it, im going to wait awhile before i fire up the welder to make sure thats what i want to do, thanks.
