Old 04-14-2003, 04:53 AM   #1
72ChevyCheyenne
72ChevyCheyenne's Avatar
Wiring Question
I purchased a guage cluster that has a Camaro tach in it so it has seperate wires from the cluster plug. With the tach wire plugged into the dist cap the engine won't start (no spark to the wires). With it unplugged the engine runs fine until I try and plug in the tach wite again. Any ideas what is going on?
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 04-14-2003, 09:39 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
sounds like you are grounding your coil, are you sure of the wiring on the tach?
sneakysnake is offline   Reply With Quote
Old 04-14-2003, 09:49 AM   #3
fatfords
fatfords's Avatar
There are usually three wires on the Camaro tachs-one is 12V, one is ground and one is the signal from the coil or distributor (HEI). How many wires do you have and are they identified or color coded?
Kent
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
