Old 10-03-2011, 10:07 PM   #1
danielwkade
Fuel Tank Swap
I'm not finding some specific information I need on fuel tanks. Right now I have a '72 K10 with an in-cab tank and an aux reserve tank. The reserve tank is very small and made of plastic. The aux fill tube is mounted behind a small metal door mounted under the belt line behind the driver door.
I want to swap to a larger capacity saddle tank to be used as my primary tank. I hope to make use of the fuel door that is already there for the reserve tank. I really don't want to do any cutting, the paint is original.
So my specific questions -
1. Will a saddle tank fit the 4wd with leaf springs?
2. Is it possible to hook up the saddle tank to the existing filler mounted below the belt line?
Thanks.
danielwkade is offline   Reply With Quote
Old 10-04-2011, 01:23 AM   #2
danielwkade
Re: Fuel Tank Swap
Edit: Turns out I was wrong, the secondary tank I have is a metal 16 gallon capacity. Were there any larger saddle tanks or was that it?
If that's as big as they come I'll just add a second tank on the passenger side.
