1981 C60 brake booster
Hi all so I am new here and looking for some help
I have a 1981 C 60 that when I shut it off the power steering pump boils over fluid. So I have read that the brake booster has a check valve that could be the issue. I see no internal check valve but I do see one that screws on and has a wire hooked up that looks like a small selenoid. How does this work ? Does anyone have a wiring diagram? Is there a manual for this truck online ? any help would be appreciated Shaun |
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: 1981 C60 brake booster
![]() Welcome to the board Shaun. Stick around, be patient and I am sure someone with experience in hydro-boost brake systems will be able to provide you with an answer or 2 to your query. Oh BTW...... ![]() Good luck and have fun Dave
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
