10-04-2011, 12:53 PM | #1 |
What gear do I have? No codes
I am trying to figure out my rear end ratio with no luck. I think it needs steeper gears but I'm not sure where it's at now. I don't have any of the codes, they're gone from the glove box. I tried marking the tire and driveshaft but unless I'm crazy the driveshaft is only turning about 1.5 rotations to the tire's 1. So I have a 1.50:1 ratio?? HAHA I don't think so...
Any suggestions without taking the diff cover off?
84 K10 Custom Deluxe: 350 crate engine w/ 4" lift |
10-04-2011, 01:45 PM | #2 |
Re: What gear do I have? No codes
3.08 would be my guess .If you have one tire stable and only turn one tire then you double the pinion rotation.
Frank.
Born and proudly residing in a Red State ! |
10-04-2011, 02:42 PM | #3 |
That makes sense. I had both tires off the ground but I was only turning one.
10-04-2011, 07:08 PM | #4 | |
Bite the bullet and take the cover off. The fluid needs to be changed anyway. The lube in the rear differential is one of the most neglected/abused things on nearly every vehicle.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
10-04-2011, 07:22 PM | #5 |
That's a good point. I'm pretty sure I'm running 3.08's and I want something steeper so I will replace all bearings and fluids when I do it.
I have to change both the front and rear at the same time don't I? The gears I mean..
10-04-2011, 08:38 PM | #6 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-04-2011, 11:24 PM | #7 |
Take the cover off. The gears have the ratio stamped right on them. 41 11 or whatever.
