Where to mount front e-level sensors on '68 dropmembered C10??
I found a place to mount the rear... but I have no idea where to mount them on the front.
The biggest issue I am coming across is that my drop member, upper and lower control arms are already powder coated. So I dont want to weld anything to them. I dont mind drilling a hole but welding is not an option. Although I can weld on the frame... its painted. Here are some pics of the rear. I welded a 16 guage plate inside the frame and mounted the sensor to it. Now I just need to figure out the front. If you have pics of where you mounted yours i would be GLAD to see them.
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
