drag it like you stole it
kickdown cable bracket..
anyone have a pic of one of these installed?
negative camber //LA\\ |
![]() Join Date: Sep 2001
Depends on the transmission: TH350 is mechanical and TH400 is electrical, unless you go with a custom setup like I did which looks mechanical from the carb, but actuates a switch mounted on the frame...
I can snap a pic of my custom setup, but it may be a while before I can get it to you (no digital camera good enough...).
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
On the same topic, does anyone have a GM part number for a kick down cable use with a 350 engine, 350 trans. & Quadrajet 4 barrel carb. I don't know how to find the # or length required. Thank you!
If it's for a 350, it bolts to the left side rear of the manifold. You can get them at the car and truck shop. http://www.truckandcarshop.com/
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
