04-14-2003, 10:22 AM | #1 |
washer fluid pump
Is there a trick to priming the washer fluid pump? When I go to spray the windshield, I can hear the pump working but nothing comes out. I'm assuming it just needs to be primed because the reservoir was bone dry when I got the truck.
duckdown 1969 C-10 |
04-14-2003, 10:26 AM | #2 |
If you pull the inlet hose off of the washer reservoir, you can inject water into the hose while you try the pump, (a helper is needed). Sometimes it it is the "O" rings in the pump, but my experience has been that the piston leaks. If the piston leaks you will get fluid running into the floor usually from the pump.
Jim |
04-14-2003, 10:33 AM | #3 |
newly minted old timer
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
04-14-2003, 10:49 AM | #4 |
Thanks guys! That was exactly what I needed.
duckdown |
