Old 10-04-2011, 09:49 PM   #1
sbc10guy
sbc10guy's Avatar
adding power steering
I have a couple questions on adding power steering to my 69 c10 that did not originally come with it. I was wondering what pumps will work off what year trucks on a 69. Also the truck not being a power steering truck i will need a new pitman arm, and i was wondering what year i can get that off of as well. Thanks
1969 shortbed c/10
1998 GMC sierra
sbc10guy is offline   Reply With Quote
Old 10-04-2011, 10:34 PM   #2
yunkyarddog
yunkyarddog's Avatar
Re: adding power steering
dont quot me on this but my 68 got a 72 pspump psgear and pit arm
Im stright up ESL student........ fixin my truck a trip to the yunkyard at the time
94 s10 4x4 4.3/5speed (dd)
68 lwb GMC 350/4speed
52 5 window GMC I6/4speed 12v (8lugs and long bed)
53 bel air 235 I6/powerglide
yunkyarddog is offline   Reply With Quote
Old 10-05-2011, 06:53 AM   #3
hugger6933
The pumps and steering boxes work a LONG time . like up to 87 or so. The onlt thing is the General changed the end type[flare vs. o-ring] on the hose. You have choices there you can remove the big nut fitting on the back of the pump[houses the pressure valve] and replace it with an older style or use a box of of a newer trck that matches the pump and the box or you also can buy conversoin fitting. Aside from the pump and bow you will need a pressure line , return line,pitman arm and I also think that the idler arm is also different. This is a swpa I am plannig for the near future on my last 70 that came in last week[along with power brakes ,headers, HEI, 4BBLand intake. rallys and a5 speed overdrive with a van tilt with smothed shifter bowls so it looks like a factory floor shift tilt]
hugger6933 is offline   Reply With Quote
Old 10-05-2011, 09:36 AM   #4
chopnchaneled
chopnchaneled's Avatar
Do a search on steering there are several great threads on this, I helped me a ton when i did mine.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 10-05-2011, 09:36 AM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
If you can get the whole set-up off of an engine with the same water pump length then you should be good to go.Don't forget to get "ALL" of the pulleys as they can be a real pain to match to a conversion like this.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-05-2011, 06:40 PM   #6
lil hoodlum
lil hoodlum's Avatar
maybe this will help.
Keith
lil hoodlum is offline   Reply With Quote
Old 10-05-2011, 09:45 PM   #7
sbc10guy
sbc10guy's Avatar
Awesome, thanks for the info and i will check out the steering section and see what i can find.
1969 shortbed c/10
1998 GMC sierra
