Old 10-05-2011, 08:39 AM   #1
66farmer
66farmer's Avatar
64-66 door gaps
What should the door gaps be and is there a easy way to adjust the doors.
Thanks for the help
66farmer is offline   Reply With Quote
Old 10-05-2011, 11:47 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 64-66 door gaps
When my body guy and I did my doors, he said they should be even. and no it isnt real easy by yourself, a floor jack is your friend and a buddy is a even better friend, he can hold your beer when needed!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-05-2011, 11:08 PM   #3
rustyrodknocker
Re: 64-66 door gaps
3/16"-1/4" would be ideal. up to 3/8 is normal my gmc was way looser than the chev and without 1/3 of the spotwelds. [which just fell apart compared to the chev] [ill still take a gmc everytime though]. i tried to lift mine up because the top was terrible. the body line doesnt line up if I get it where I want it. In those cases you have to build up the edge with a piece of tig wire. if you try to get the gap at the front of the door under a 1/4 they open into the fender real easy. custom guys like an 1/8" but these trucks dont take to that very well with factory hinges.
rustyrodknocker is offline   Reply With Quote
Old 10-06-2011, 09:14 AM   #4
dthela
dthela's Avatar
Re: 64-66 door gaps
door front edge slightly inside fender, be careful opening door till adjusted!!!!!!!!
dthela is offline   Reply With Quote
Old 10-06-2011, 09:33 AM   #5
66farmer
66farmer's Avatar
Re: 64-66 door gaps
Thanks for the info. I,m just test fitting the door know because I replaced the rocker. It all looks ok not great the line between windshield and door is the worst a little tight at the bottom. I have seen other trucks with the same gap problem. Have you guy,s had this problem ?
Old 10-06-2011, 05:01 PM   #6
dthela
dthela's Avatar
Re: 64-66 door gaps
not at that point.
Old 10-06-2011, 05:34 PM   #7
64fleetside
Re: 64-66 door gaps
specs are 5/32" all around except 1/4" at the bottom, IIRC.
64fleetside is offline   Reply With Quote
Old 10-06-2011, 08:54 PM   #8
rustyrodknocker
Re: 64-66 door gaps
mine has a little of that. parallel gaps on two adjacet sides mismatch on the opposite. no biggie. easiest way to fix it is backup 25 feet. my rockers are inset from the cab 1/8" to a full 1/4" and the bed was put on crooked this is my 68. 292 manual trans, power nothing. no hand fitting from the factory. looks like it was built on a moving line and it was. I never noticed a poor fit up intill I got around modern cars. Then I noticed something was different, and it hit me. The fit up is great . on all of them. but the paint sucks. on almost all of them. Ill take the old paint anyday. I think the in 70's paint quality peaked. on trucks anyway.
Old 10-07-2011, 08:54 AM   #9
64fleetside
Re: 64-66 door gaps
They were work trucks back then, not meant to be pretty-I've had two low mileage originals, door/fender fit was poor in regards to gaps, but they always shut good. Many body "adjustments" back then were applied by rubber hammer. The door/fender gaps on the one I'm building is much better than OE, but it took some work/time to get there.
My buddy's '69 C10 had the worst fitting OE sheetmetal I've ever seen, but everything shut/opened perfectly.
Old 10-07-2011, 04:35 PM   #10
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: 64-66 door gaps
Old 11-13-2022, 11:33 PM   #11
Auctioneerhere
Re: 64-66 door gaps
I have noticed the bottoms of the doors are the worst for fitting, I have a 61 now that fits decent everywhere except at the bottom of the door & the cab corner.
This is on a truck that has all original solid sheet metal. I blasted it to bare metal inside & out, so no surprises. I looked at ten of my other parts trucks and GM had them all over the place. I may wind up slicing the cab corner vertically to put the gap closer to the door & weld up the releif cut.
Auctioneerhere is offline   Reply With Quote
Old 11-13-2022, 11:53 PM   #12
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Re: 64-66 door gaps
I’ve always Used a Paint Stick To Start with
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
