Old 04-14-2003, 12:36 PM   #1
C&C Chevy
C&C Chevy's Avatar
Disconnecting fuel lines?
I've got the tank dropped about 4" and the fuel lines are still connected. How do I get them disconnected? There are four of them.
C&C Chevy is offline   Reply With Quote
Old 04-14-2003, 03:10 PM   #2
C&C Chevy
C&C Chevy's Avatar
Well , I've decided to just take the bed off! I'm afraid to drop the tank any farther to get at fuel lines. They're tight as it is.
I got a few friends coming over and I went ahead and took the bed bolts off. There is one that is spinning in the hole. How can I get this out?
Old 04-14-2003, 03:30 PM   #3
BaggedC10
Under construction!
BaggedC10's Avatar
I had that happen and I ended up cutting the bolt in half.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 04-14-2003, 03:40 PM   #4
C&C Chevy
C&C Chevy's Avatar
Where exactly did you cut it at? And what did you use to cut it?
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
Old 04-14-2003, 06:52 PM   #5
C&C Chevy
C&C Chevy's Avatar
OK, finally got everything changed out and hooked up. I turn key and hear the lil pump working! I learned alot this time around! If I have to do it again, it would go alot quicker! Thanks for the help.
Robert
Current:
Past:
