View Poll Results: fix it? or start over? | |||
screw it, some dynamite should finish the rest and a new rear is in order |
11 | 78.57% |
get some good used pieces and cobble it back together |
3 | 21.43% |
Voters: 14. You may not vote on this poll |
I know one is a spider gear how about the others? off my buddys truck and we are wondering if humpty dumpty can be put back together again?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Re: HELP! identify the scatterd pieces
If you have a stock rear end now and dont know how to set the backlash yourself and have to take it to a shop, it would be cheaper to find a used rear and swap the whole thing out.
John 82 Chevy Silverado 350ci/TH350 ![]() |
Moderator
![]() Join Date: Oct 2008
That doesn't look good at all.
Get a whole new rear from the junkyard. itll take pulling the covers off a few to find the one you want that isnt damaged and/or has the ratio you want. i got my last one for approx $45 for a 12 bolt. one note, van rears DONT fit, whatever you buy has to come from a squarebody, 73-87.
if the pieces of metal got into everything else, the only part of that thing that is still good is the case itself (maybe) and the maybe the carrier (not the gears, just the carrier). |
The biggest problem in the puzzle is the round shaft, it's hardened steel. The force required to break this peice is hard to imagine. The housing is probably screwed. Without jigs and alot of money it's cheaper to replacing the assembly. Good luck, Ron..
#6 | |
so we are thinking maybe an 88-98 rear diff would have more chance of being a posi i know you have to re weld spring/shock hangers but it should just bolt in and go after that right?
Yes it will bolt in after you move the spring perches but the 88-98 rear end is just a bit wider I believe. 1/2 inch or so, it will push your tires closer to the lip of the rear fender. Which looks better in my opinion but you will have to check your wheel clearance.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
Looks like what is left of a Gov-Loc rear carrier. They are known for doing that . Mine shot pieces through the rear cover when it came apart back in the day. I have never had another with the Gov-Loc setup.
Frank
Born and proudly residing in a Red State ! |
so how do i tell if its a gov loc vs conventional posi?
