Old 10-05-2011, 07:55 PM   #1
flashdad
Rochester 4 jet question
I have a 67 pu with a 71 corvette engine (350). The carb is a Rochester GM 4 Jet with a little RP insignia on it. Nearest I can figure it came off a 65-66 Chevelle. Can anyone tell me what model number this carb is? Everything I've seen says there should be a number somewhere on it but the above info is all I can find. There's not a tag on it. PO did a lot of engine/carb work on it before he killed himself last year. Any help would be appreciated.
Thanks,
'67 Chevy C10
'68 GMC PU
'98 Turd F150 4x4 (I think it may be a chevy under the logo it's such a good truck)
'10 Mustang
"Life's tough - it's even tougher if you're stupid." John Wayne
flashdad is offline   Reply With Quote
Old 10-05-2011, 08:35 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Rochester 4 jet question
According to my 65-72 Chilton's the 65 came with a 327 that used a Rochester 4GC. The 66 Chevelle with a 283 used a Rochester 4GC also and the 327 used a Rochester 4MV.
Just remember that these vehicles are over 40 years old and a lot of mechanics may have made some changes there.
68gmsee is offline   Reply With Quote
Old 10-05-2011, 10:03 PM   #3
flashdad
You're not kidding. I got (supposedly) the correct kit for it, but it was dead wrong. So I shopped around looking at different models and years based only on the gaskets and piston (the one I have has a crook at the top - not a straight leg), The one I found was off a 65 Chevelle 327. Crazy that it fits on my 71 vette 350. Thanks anyway!
'67 Chevy C10
'68 GMC PU
'10 Mustang
Old 10-05-2011, 11:46 PM   #4
webfoot
Is there not a part number stamped on it?
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 10-06-2011, 12:01 AM   #5
flashdad
Nope, not a one. The only thing it says is Rochester, GM, 4 Jet, and then there's a small RP. I was thinking replacement part, but not sure, that's why I was asking. the only gasket / repair kit I could find is the one for the 65-66 Chevelle 327. The one for the 350 (which is what I ordered) has larger gaskets and a straight pin piston. My piston hooks at the top to tie into the accelerator linkage with a clip.
'67 Chevy C10
'68 GMC PU
'10 Mustang
Old 10-06-2011, 10:32 AM   #6
MacGyver72
MacGyver72's Avatar
On the throttle linkage side but on the back secondary rear tower should be a vertical number that begins with 170. It will probably be VERY hard to see because they were only slightly etched in. wet the area down and wipe a dirty finger over it. You should see a number. (dirty oil on the finger works well for this.)
MacGyver72 is offline   Reply With Quote
