Old 10-05-2011, 09:23 PM   #1
juiceman650
juiceman650's Avatar
Ideal Running Temperature
Hey guys, just wondering what an ideal running temp for my truck should be. I was driving it the other day and sitting at read lights it would creep up to almost 230 F but running it would drop to the low 200s. Is this an okay range?
1975 Chevy Cheyenne w/ v8 350 and TH350
Siverado interior
Fleetside bed
aka "The Beast" aka "Cheyerado"
juiceman650 is offline   Reply With Quote
Old 10-05-2011, 09:24 PM   #2
Your41Plague12
Your41Plague12's Avatar
Re: Ideal Running Temperature
That's definitely hot. Should run about 180. Are you running a thermostat?
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 10-05-2011, 09:54 PM   #3
cjlinkster
cjlinkster's Avatar
For the 80's models, operating temps should be between 190 -220. The factory thermostat should be 190 degrees. This was due to all of the emission crap that are installed on the engines.
Driving my truck around, it normally stays at around 210.
I wouldn't worry about temps right at 230; any higher would be a concern though.
1984 C20, 454, 4 speed named "Gold Member"
cjlinkster is offline   Reply With Quote
Old 10-05-2011, 10:36 PM   #4
Rogue_Alphonse
Rogue_Alphonse's Avatar
I've always had mine run between 160 and 200, just to be safe. 230 while sitting isn't too much of a worry, though
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 10-06-2011, 02:14 AM   #5
juiceman650
I think I am, not 100% sure though.
Siverado interior
Fleetside bed
Old 10-06-2011, 02:16 AM   #6
juiceman650
Yeah, mines a 75. The only concern/problem I have is that once I turn it off after it gets around 200, it takes a while to turn it back on. I've been thinking of flushing the radiator and replacing hoses and thermostat.
Siverado interior
Fleetside bed
Old 10-06-2011, 02:17 AM   #7
juiceman650
Yeah, I'm not 100% on the numbers cuz I last drove it on Sunday. I will definitely check my temp gauge to get the right temp.
Siverado interior
Fleetside bed
Old 10-06-2011, 05:44 PM   #8
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
Interesting.. I heard the same thing. Since mine has all that Smog crap.. I did however opt to replace the OEM 3 vein with a 4 vein radiator.. and a 180 thermostat.. it rarely goes above 180.. except in the Summer with the A/C on. Does having a hotter running engine.. effect the way it performs? Say.. idling smoother.. better gas mileage etc...?
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 10-06-2011, 06:58 PM   #9
Goldfinger
Goldfinger's Avatar
mine never goes over 160 with a big truck high efficiency radiator. even in florida.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 10-06-2011, 07:41 PM   #10
71swb4x4
71swb4x4's Avatar
160 is too cool and is hurting the efficiency of your engine. I think you want to be between 190 and 210.
To the OP - make sure you are running a thermostat. Having no thermostat can cause the coolant to pass through the radiator faster than the radiator can cool it. Also make sure your temp gauge is accurate.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-06-2011, 08:15 PM   #11
juiceman650
Well I just checked it out and I checked my radiator. Guess what I found! Emptiness. Turns out that the coolant was thrown over into the reserve tank.
Siverado interior
Fleetside bed
Old 10-06-2011, 08:43 PM   #12
71swb4x4
71swb4x4's Avatar
If it was in the reserve tank and the radiator is low you probably have a problem with your radiator cap. Replace it and see what happens.
Old 10-06-2011, 08:45 PM   #13
juiceman650
Oh and I checked my temp gauge. When I sit and idle, the needle is below 230 so I'm estimating its reading anywhere from 200 to 220. And when I drive it'll drop to around 190. The sensor is in the same spot as the OEM Gauge. As for the thermostat, Im still insure if I'm running one.
Siverado interior
Fleetside bed
Old 10-06-2011, 09:10 PM   #14
cjlinkster
cjlinkster's Avatar
For a quick check...
When the engine is cold, take the radiator cap off and then start the engine. If you see coolant flowing; then chances are you either have a stuck open thermostat or it has been removed.
My truck seems to run best with the 190 degree thermostat. On my particular truck (1984), the vacuum advance source of vacuum is controlled by a temp switch.
