10-06-2011, 08:30 AM | #1 |
Help on some rallys
I have a chance to get a set of 8 lug rallys for my 82. they came off of a 93 and have the center caps and all. Will the LUG NUTS fits. If not, where can I find some that will work, I wanna put the center caps on to
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
10-06-2011, 10:34 AM | #2 |
Re: Help on some rallys
The thread will be differemt between the 82 & 93 so you'll need conversion lugnuts. They're available @ many hubcap places.
10-06-2011, 09:15 PM | #3 |
Where would that be. I can't, off hand, think of any place around here to find those conversion nuts
10-07-2011, 12:00 AM | #4 |
It can be as easy as 1, 2, 3....
1) Go to Google (or any search engine) 2) Type in what you're looking for (I typed 'Chevy truck conversion lug nuts') 3) Start looking through the first several hits to see if anything listed works This was within one of the first several hits.... http://www.ezaccessory.com/GM_1_2_Ex..._p/98-0006.htm
10-07-2011, 11:46 AM | #5 |
I called them and they said they don't have the ones to convert from a 93 to 82
10-07-2011, 01:05 PM | #6 |
Orioles auto parts can get them in the same day but for 32 of the it's about 150.00
10-07-2011, 01:58 PM | #7 | ||
The 93's are metric thread (14mm). An 82 would need 1/2" thread unless the 3/4 tons were 9/16" (that I'm not 100% sure about). Edit* Another quick Google search says the 3/4 tons were indeed the larger 9/16" diameter. I went back to the same site & they have these listed.... http://www.ezaccessory.com/GM_9_16_E..._p/98-0009.htm Quote:
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-07-2011 at 02:15 PM. |
10-09-2011, 01:11 AM | #8 |
I got a whole set off EBAY for 47.00
10-09-2011, 08:01 AM | #9 |
Can you post a pic of the wheel?
I'm not following when you say "8 lug rally off a 93". Thanks in advance - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-09-2011, 10:40 AM | #10 |
the 88-98 factory 3/4 ton wheels
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
10-09-2011, 06:53 PM | #11 |
Thank you.
It's not a very styled wheel, hence my confusion - but it does have a chrome ring and cap, so I guess that could make it a rally wheel... K
10-09-2011, 09:40 PM | #12 |
That's the only reason I called them rally's I like the way they look now trying to decide it I wanna paint them black to match the truck or repaint them Silver
10-10-2011, 12:04 PM | #13 |
Paint them black, but leave the center caps and rings chrome. I love that look.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
