Old 10-06-2011, 09:59 AM   #1
Coupeguy2001
Coupeguy2001's Avatar
Is anyone still running the original generator?
I have been running an alternator for so long, I forgot about the lowly generator till someone wanted to buy my old one!!!
Coupeguy2001 is offline   Reply With Quote
Old 10-06-2011, 12:41 PM   #2
OrrieG
OrrieG's Avatar
Re: Is anyone still running the original generator?
Did until 2000. Switched over to altenator, sold my two working generators (I always carried a spare in case it puked in the boonies) for $15 to a tri-five restoration guy.
OrrieG is offline   Reply With Quote
Old 10-06-2011, 01:08 PM   #3
Root2812
Root2812's Avatar
I've still got the generator on mine but mine is in the middle of a restoration and hasn't seen more than 2 miles in the last 20 years.
Root2812 is offline   Reply With Quote
Old 10-06-2011, 03:41 PM   #4
Coupeguy2001
I carried brushes and bearings in the glove compt. for years, Then when the generator did fail, it was a shorted field coil. Didn't have that in the glove compt. I had to turn on everything to keep from boiling the battery. The 'ol volt meter was reading 17 volts unloaded, and 15 volts with headlights, heater, wipers on a dry windshield, foot on the brake to make the stoplights go on, and the original radio all workin'.
I got a one wire alternator the next day. I used a corvette alternator bracket in aluminum.
Old 10-06-2011, 05:30 PM   #5
mr48chev
mr48chev's Avatar
I couldn't begin to tell anyone when the last time I ran a generator on anything of my own was. Probably the 55 Ford Sedan that we had that my wife drove to work for a few months in the early 70's.
I'm building a little roadster with a flathead six in it that may keep the generator to keep the car a bit more period correct but it won't have anything on it that draws power except a little box style heater that hopefully will take a bit of the chill off cool mornings and evenings. a hundred miles one way will probably be the longest road trip it ever makes too unless it is on it's trailer behind the 48.
A generator does have one advantage over an alternator though. You can push start a car with a stone dead battery with a generator as it will charge without having any voltage to it to excite it like an alternator needs.
Old 10-06-2011, 06:21 PM   #6
meter swinger
meter swinger's Avatar
Still got one on mine. Im about to rewire the beast though, then ill probably go to a powermaster look a like or something, since the motor will be dressed in early vette garb.
meter swinger is offline   Reply With Quote
Old 10-06-2011, 06:42 PM   #7
Dan in Pasadena
Dan in Pasadena's Avatar
I'm running a generator on mine. I plan to update to a polished alternator at some point but its not a priority. Truck's not a daily driver and it has NOTHING; well almost nothing, electrical to run. No radio, don't drive it with the lights on cause I virtually never drive it at night.
Air cleaner has since been changed to matching finned unit and firewall, inner fenders redone in black. But the generator is still there.
Dan in Pasadena is offline   Reply With Quote
Old 10-06-2011, 07:16 PM   #8
Dan in Pasadena
Oh, P.S. Double hump heads so no holes in the heads for the typical mounts. I've heard there are sources for brackets that do NOT use holes in the heads, but I could use advice or links if anyone has good ones.
Old 10-06-2011, 07:45 PM   #9
vwjohnny
vwjohnny's Avatar
Yes... Definitely... Well, until it quits.
vwjohnny is offline   Reply With Quote
Old 10-07-2011, 01:52 PM   #10
Divine 59
Running a generator and have no regrets. I'll be glad to have mine back on the road. Currently under restoration.....$$$
Divine 59 is offline   Reply With Quote
Old 10-07-2011, 06:54 PM   #11
tmoble
Dan, this guy has the best brackets out there and they fit.
http://www.alangrovecomponents.com/index.htm
tmoble is offline   Reply With Quote
Old 10-07-2011, 08:29 PM   #12
Dan in Pasadena
Thanks so much. I'll be studying the website. Anyone else know of a source for brackets? I was hoping for something to mount down low whereas these all appear to mount prominantly up high. That'll work for me I'd just like to make the alternator and AC compressor much less noticeable.
Old 10-07-2011, 10:28 PM   #13
solidaxel
solidaxel's Avatar
Check with Bill's Hot Rod shop in Covina, I have used his brackets and pulleys on all my projects
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-07-2011, 10:38 PM   #14
Divine 59
@ Dan in Pasedena
Is your motor the 235? I may have a generator bracket? I will have to dig through my stuff. I'm not sure if I have a bracket with my spare generator or not.
Let me know....
Old 10-07-2011, 10:40 PM   #15
Divine 59
I guess I did not read enough up there.. Your truck is a V8. My generator brackets will not work...
Old 10-07-2011, 11:03 PM   #16
Dan in Pasadena
Ha, ha I read your first post and was about to say...."Uh....see the photo..."
Solidaxel - Thanks, someone told me about a local shop but I forgot the name and that must be it. Definitely will look into them.
Old 10-07-2011, 11:43 PM   #17
northerngmc
northerngmc's Avatar
Yup original 235 with the generator. Never worried about it until I read this!
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 10-08-2011, 06:39 PM   #18
Red Foreman
Red Foreman's Avatar
Original here too in my 59 235, like Dan I have no need to drive at night.
Red Foreman is offline   Reply With Quote
