BIG CHEVY 3600 LONGBOX
Radiator overflo tube
Two openings on one end. Does it matter if the open ends are at the top or bottom?
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 |
Re: Radiator overflo tube
The openings go to the bottom and the hoses from the radiator goes on the shortest tube in the overflow, that way the water fills up the overflow then comes out the tube closest to the top...
Both tubes are the same length. http://s729.photobucket.com/albums/w...OverfloEnd.jpg
#4 | |
Wow, the top screws off! No way to know that without directions. I know it's a simple operation but looking at the top on this thing you would never guess it would unscrew.
Thanks for the help, otherwise it would have been a 50/50 deal as to what tubes I used.
looked at you pictures and you've done some nice work on your truck, glad i could help..
Thanks Buddy...
#8 | |
