1966 c10 rear end
Does anyone know if I use a 72 5 lug rear end,can I run 8 in. rallies and still lower my truck?It is a stepside if it matters.Thanks.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: 1966 c10 rear end
I have that exact set up, mine is lowered 4" in rear, I have 275/60/15 BFG tires on it and nothing rubs. mine is fleet but shouldnt matter
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
2nd gen axles are IIRC 1.5 or 2 in wider
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201 no garage, no shop, limited storage space and tools....no problem. |
SIR
...on fleetsides it"s a safe bet to trim 1-1 1/2" out of the rear fender lip...start at 1" and adjust from there...
66long low fleet http://community.webshots.com/user/LVNR66 |
Thanks guys for the quick replies.
60-66 Nut
![]() ![]() Join Date: Mar 2007
The '71 and up rear ends are 1.5" wider than the '70 and older rear ends. If I'm not mistaken, the stepsides have slightly less room for tires than the fleetsides.
meowMEOWmeowMEOW
Stepside with notched frame and lowered about 5-6", with almost 14" of tire under it on a 12inch wide rim. Bed is cut tho.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
