10-06-2011, 07:53 PM | #1 |
Motor mounts sold out....now what??
After a moderate amount of research I decided on the ECE mounts for my 5.3 swap. I went by to pick them up today and they informed me a portion of the mount is made in house and a portion is sourced from GM. GM has discontinued making there half!!!! So, I am wondering what my next best option is as far as mounts. I would like to retain my AC compressor in the stock location if possible. All of this is on my 63 C10 by the way. What mounts are everyone else having luck with? Just a heads up, Im not a great fabricator or welder so something bolt in would be preferred. Thanks!!
10-06-2011, 09:07 PM | #2 |
Re: Motor mounts sold out....now what??
iv'e got a new pair of ece prothane mounts i'm not going to use maybe they would work for you. they are 2-3/8" between the ears,2-3/4" tall.
Learn to deal with reality, or reality will deal with you. |
10-07-2011, 06:20 PM | #3 |
meowMEOWmeowMEOW
I don't run a/c so I'm not sure if this will work;
I just used the standard cheap swap plates, stock mounts and stock 6 cylinder perches. Moved the perches to the front hole, and welded the mounts in place to be secure. You don't HAVE to weld them, some grade 8 hardware would work fine as well.
10-07-2011, 10:23 PM | #4 |
Still Just Havin Some Fun!
If he can't use them I might be interested in them...
a green one with some stuff done to it.... |
10-07-2011, 10:36 PM | #5 | |
67-72 parts collector,…
I would veriify that from ECE and just use a used set of frame stands.
10-08-2011, 10:21 AM | #6 |
I have been looking at dirtydingo for motor mounts, they offer adjustable ones that look really cool.
I used stock motor mounts with transdapt plates on the motor....
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
10-08-2011, 01:51 PM | #7 |
Thanks for the replies everyone! Rick, are those LS style mounts? It looks like from the picture they have the regular small block on one side but I'm confused where the forked side goes. Lolife, I believe you are correct, I may see if I can stir up some frame brackets and ask if they will sell me the top "half" only. Shon, are you happy with the trans dapt mounts and where your engine sits fore and aft?
10-08-2011, 01:58 PM | #8 | |
I used the stock style mounts (poly replacement) thinking it would be a 'cheaper' route and wanted to show people that you do not have to get the 'high dollar' stuff. but in the end its within a few bucks, slightly cheaper and works but do like the ECE set up. Just wanted to be different.
10-08-2011, 02:58 PM | #9 |
they are Ls mounts, I have 1969 Camaro frame stands, the forked part mounts to the frame stands of your choosing, lots of guys make their own.
10-08-2011, 08:53 PM | #10 | |
Sorry, those are not LS engine mounts. LS engine mounts use four bolts to mount to the block, those are sbc mounts! Posted via Mobile Device
1968 C10 LS2/4L70e swb fleet side. ECE front disk conversion and 3.5/5 drop. SOLD. 1968 C20 Custom Camper 396 50th survivor! SOLD to northerngmc |
10-08-2011, 09:06 PM | #11 |
they are LS mounts, I had them mounted to plates that adapt to the LM7 I have. I have a set of small block Chevy mounts i can show you if you like.
10-08-2011, 09:18 PM | #12 | |
Posted via Mobile Device Posted via Mobile Device
10-29-2011, 05:35 PM | #13 |
So this is a bummer, ECE no longer sells there Ls conversion kit?
Thanks! Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help. Last edited by usmcchevy; 10-29-2011 at 09:43 PM. |
10-30-2011, 09:15 AM | #14 |
I just bought the kit from ECE last week. I would call and check.
http://www.earlyclassic.com/catalog....ry=New%20Items Last edited by exploderjim; 10-30-2011 at 09:17 AM. Reason: added mount link |
