Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 10-06-2011, 07:55 PM   #1
Pacific Fabrication
Pacific Fabrication's Avatar
LSx Engine X-members for the 4wds, 67-72 and 73-91
Pacific Fabrication is proud to offer our LSx-members. When swapping in an LS engine you often run into issues with the stock 4wd engine x-member. Our x-members take care of those issues.
The 67-72 4wd x-member comes with motor mounts and adapter plates to bolt to the block. It replaces everything between the rails. It is meant for the end user to be able to set the location of the engine. Stock, forward, back, whatever you decide. It sells for $399, complete with hardware. Additional $60 for poly motor mounts.
The 73-91 4wd x-member bolts to the stock motor mount towers, just replacing the x-member. It it 2 pieces that bolt together allowing it to be installed with the engine already in place. Or removed to facilitate removal of the oil pan. It sells for $299, complete with hardware. Motor mounts not included.
(I need to find my better pictures of this kit)
To order please give us a call, 408-250-1772
Pacific Fabrication is offline
Old 10-07-2011, 01:10 PM   #2
Shon
Re: LSx Engine X-members for the 4wds, 67-72 and 73-91
Nice
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline
Old 10-17-2011, 12:15 PM   #3
Thealien
Thealien's Avatar
nice to see you guys here. I have recomended your product to a few members here and have pics and a link in my thread!
Thealien is offline
Old 10-17-2011, 03:58 PM   #4
Pacific Fabrication
Thanks for the support!
Old 10-20-2011, 12:20 AM   #5
SWB4x4
SWB4x4's Avatar
I bought one of your kits for my rig just havent installed it yet
J.T.
1972 SWB 4X4 on 35"s with 6" lift all around 3/4 ton running gear with high steer and 4.88s 350/th350. SOON TO BE DONE:2" higher in front 37"s,LSX Swap,Hugger Orange & White Paint Scheme,Air Conditioning,Power Windows & Locks,Complete Gauge Kit,Tank Relocation,Double Din Nav with full Audio System.
My Build Thread http://67-72chevytrucks.com/vboard/s...=1#post4169140
SWB4x4 is offline
Old 12-12-2011, 06:54 PM   #6
Pacific Fabrication
Thanks for all the orders guys!
Old 12-29-2011, 12:04 AM   #7
my4by2
my4by2's Avatar
That's what WFO used in my truck & it worked out GREAT!!!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline
Old 01-20-2012, 01:51 AM   #8
Crash_OK
Crash_OK's Avatar
Just finished up an install of this product. Great product.. below is a link to my write up on the x-member.
http://67-72chevytrucks.com/vboard/s...99#post5134299
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline
Old 01-20-2012, 02:15 AM   #9
Pacific Fabrication
Awesome write up. Thanks for the props. Glad that after talking with you, you got it all figured out.
-Jason
Old 03-02-2012, 11:52 AM   #10
jays68yak
jays68yak's Avatar
Got mine installed a few weeks back.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline
Old 04-17-2012, 05:53 PM   #11
Pacific Fabrication
Bump!
Old 04-23-2012, 04:27 PM   #12
Pacific Fabrication
Thanks for the orders guys! Several left the shop today, and several more ready to ship.
Old 12-07-2013, 06:03 PM   #13
Auctioneerhere
DO you have a kit for a 64-66 frame?
Auctioneerhere is offline
Old 12-09-2013, 01:28 PM   #14
Pacific Fabrication
We do not currently have a specific kit for those years. I have sold a 67-72 to someone who was going to try it in a 60-66 truck. I never heard back from him on if it fit or if he had to do a bunch of work to get it to work for him. I would almost think that it would work. Can you grab the width of the inside of the frame and the height on the inside of the C in the frame where the stock on is? Those are the only things that come to mind if it would work or not.
Old 01-03-2014, 01:13 AM   #15
padresag
I did put the 64 eng mount crossmember in. no problem. if you are going to use an a/t in the 63-6 4 x 4 chassis it would be recommended that you install a c/member as such as you are going to remove the one at the bell housing and that frame needs support in that area then
ron
padresag is offline
Closed Thread
