10-06-2011, 08:21 PM | #1 |
who has a diagram for TH400
I am looking for a simple wiring diagram for my TH 400 so I can wire it up to get kick down to work ... any help would be great thanks gang
when the smoke clears all your gunna see are my Tail lights |
10-06-2011, 09:29 PM | #2 |
Re: who has a diagram for TH400
sorry I don't have an answer for you. In fact I am about to have the same issue Consider me subscribed.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
10-07-2011, 05:29 AM | #3 |
Here is a picture of the stock kickdown switch. There are two wires connected to the switch, one is power the other goes to the detent solenoid on the TH 400.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
10-07-2011, 10:31 AM | #4 |
ok thanks Jim just what I wanted to know
10-07-2011, 04:07 PM | #5 |
Pink Ignition switched power to a switch. Switch normally open. Switch closes at wide open throttle. Sends power through an orange wire to the male terminal on side of TH400. I have seen the switches on the pedal inside, not sure which have it like the photo above and which are on the pedal.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
10-07-2011, 07:49 PM | #6 |
71-72 have the kickdown switch on the gas pedal, 70 and older have the switch on the carburetor.
Jim
