Old 04-14-2003, 03:43 PM   #1
VNMOUS
Step Side's Rule
Wink sway bar
HEY MEMBERS, BEEN AWAY FOR A WHILE AND WORKING TOO MUCH. I DID FIND TIME TO INSTALL A FRONT SWAY BAR THIS PAST WEEKEND. LOVE THE RESULTS, HIGHLY RECOMMEND THIS UPGRADE.
DANO
07 Silverado Classic
67shortstep
76 stingray
95 cobra
66 Mustang Coupe 289
VNMOUS is offline   Reply With Quote
Old 04-14-2003, 08:51 PM   #2
SideStepper
OK, I am interested, give us the details! Did you install a new "out of the box" sway bar kit, if so who is the dealer/manufacturer? Was it a junk yard find, if so what is the donor vehicle? I have heard good things from many board members on installing a front sway bar on these old trucks. I don't want to be the last one on the block to put one on! Sounds like Iam goin to have to do it, just to keep up with you guys!
SideStepper is offline   Reply With Quote
Old 04-15-2003, 08:16 AM   #3
VNMOUS
Step Side's Rule
IT WAS FROM A DONOR TRUCK. I PURCHASED IT FROM AN INDIVIDUAL NOT SURE WHAT MODEL. IT WAS AN EASY INSTALL, JUST HAD TO DRILL OUT TWO RIVITS AND BOLT ON. I ALSO USED NEW BUSHINGS. BIG DIFFERENCE IN HANDLING FOR ONLY $35.
DANO
67shortstep
76 stingray
95 cobra
Old 04-15-2003, 09:15 AM   #4
dubie
dubie's Avatar
I have a 1 1/8" sway bar from a late 70's chevy and picked it up for only $20 at the local yard, and that included all the hardeware
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 04-15-2003, 10:00 AM   #5
fatfords
fatfords's Avatar
I did that same thing a couple of weeks ago-highly recommend it too! I bought the front brackets from the local Chevy dealer for under $10 each, then pulled a 1 1/8" sway bar/clamps/bolts from a mid 80's Suburban for another $10. I used the original bushings, but have ordered new replacements.
It is an easy mod with very noticeable results. I can now go around a corner and not worry about scraping my mirrors on the pavement!
Kent
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
Old 04-15-2003, 12:18 PM   #6
basketcase
basketcase's Avatar
I also used a 1 1/8 in bar from a donor truck but I mounted it on lowered brackets and polygraphite bushings from Early Classic.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 04-15-2003, 12:45 PM   #7
fatfords
fatfords's Avatar
Originally posted by SideStepper
OK, ...if so what is the donor vehicle? I have heard good things from many board members on installing a front sway bar on these old trucks. I don't want to be the last one on the block to put one on! Sounds like Iam goin to have to do it, just to keep up with you guys!
SideStepper,
Donor trucks would be 67 to 87, Suburbans would be 67 to 91 (I think that is the right year). Bigger bars are available on heavier vehicles and as optional equipment on those years.
Kent
'05 GMC crew cab
Old 04-15-2003, 02:23 PM   #8
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
I just did it two weeks ago too...1 1/4" bar made a huge difference. New Poly bushings, the hardest part were the damn rivets, other than that, its was amazingly easy, even while laying on the ground in the dirt.
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 04-15-2003, 02:27 PM   #9
VNMOUS
Step Side's Rule
REAR SWAY BAR
I LIKED THE RESULTS FROM THE FRONT SWAY BAR SO MUCH THAT NOW I WANT ONE FOR THE REAR. ANYONE KNOW OF A GOOD DONOR FOR A REAR SWAY BAR?
DANO
67shortstep
76 stingray
95 cobra
Old 04-15-2003, 03:53 PM   #10
Low69CST
i have an 89 Camaro rear bar under my truck. I have a thing about it on my website you check out, just got alot of damn pop-ups.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 04-16-2003, 09:36 PM   #11
SideStepper
Hey, all you guys, thanks for the info! I can see that this is a FAST group to keep up with!
Old 04-17-2003, 04:26 PM   #12
pinky350
From a 73 Chevy truck up to87 that I know of.
pinky350 is offline   Reply With Quote
Old 04-17-2003, 06:02 PM   #13
70cst10
It's definitely worth the time. I should have installed mine a long time ago, but better late than never.
Milan
1964 Chevelle SS 283/M20
70cst10 is offline   Reply With Quote
